2008 RBP not starting
Old Jul 6, 2013 | 06:25 PM
mashina2010's Avatar
So wondering if I can get some help on this problem, I got a Auto 2008 TL, the car is not starting at all, dash lights are not coming on and the interior lights wont come on at all also, I've so far checked all the fuses inside and out and all are good, turning the key over to start doesn't do anything, no click from starter or engine. I have a brand new battery in it and fully clamped down and snug, and all wires are in perfect condition. so any help will do at solving this problem.
Old Jul 6, 2013 | 07:09 PM
j_u's Avatar
j_u
how old is the battery? same thing happen to me with a battery that was about 7 months old. turned out the battery was the problem even though i had it tested at a few locations and all of showed that it was good.
Old Jul 6, 2013 | 07:50 PM
battery is couple weeks old
Old Jul 6, 2013 | 11:46 PM
carz0159's Avatar
try jumping it, it could of died, especially if no lights are coming on.
Old Jul 7, 2013 | 01:19 AM
Already tried that also, it was a no go
Old Jul 7, 2013 | 04:04 PM
dannyz's Avatar
TLicious Type S
Test the voltage from the battery with a voltmeter. If you have 13v, then there is a break in the circuit downstream. (As I recall) the battery harness connects to ground (check connection here), and to your ignition, and starter. Check each of these connections to determine where the break is.
Old Jul 8, 2013 | 06:30 AM
Project_CLean's Avatar
MMkay.
Check the Multi-Fuse block in the underhood fuse box. It's the thin long fuse about 2 inches long black in color with gold lettering with a screw holding it in the fuse box.If that blows, you will have the same symptoms as a dead battery.
Good luck.
obert
Dec 14, 2015 11:36 PM
Krystynoneill
1G RDX (2007-2012)
Sep 15, 2015 09:57 AM
Rcelestino93
Sep 11, 2015 12:15 PM
gcutchin
Midwest
Sep 8, 2015 09:02 PM
