2007 TL Transmission Trouble
I purchased my 2007 TL 3.2 about a year ago. It quickly began to experience rough shifting from 1st > 2nd, 2nd > 3rd, etc. It it violently jerks the most in the shift from 1st > 2nd gear with decreasing intensity as the gears go up. Sometimes it will downshift rough into 1st gear when slowing down.
I have done quite a bit of reading and repairing over the past year since I bought it in an attempt to fix this problem. I have already:
Replaced all 3 clutch pressure switches (2x 28600-RKE-004, 1x 28610-RKE-004)
3x3 drain and refill using HONDA ATF-DW1
Replaced all motor and transmission mounts, which were destroyed, with OEM mounts
After doing each of these I have noticed no change in the shifting of the transmission for better or worse. As I've said it's been ongoing for about a year with no improvement or worsening. There are no codes detected by OBD scanner. I am at a loss here.
I have been told that this part could also be the culprit to this problem:28250-RDK-014
Thanks.
28250-RDK-014
Does anyone have any idea if this solenoid could indeed be the causes of the rough shifting? I want to know before I spend $300+ to replace it to no avail. Or will this problem just require a complete rebuild or new transmission?
Thanks.Try reseting the trans computer super simple and could really make a difference, the video below should explain how to do this I know it works on my 2004 tl im sure it would on an 07 as well
https://youtu.be/zRcPHjurh1g
