2007 TL transmission
Old Jun 24, 2010 | 02:46 PM
eppy26's Avatar
Red face 2007 TL transmission
Was wondering if anyone lives near the Bel Air Md. area thats knows anything about TL Transmissions. have 50,900M, which is still under warranty, but am a little concerned with how the car shifts from 1st to 2nd gear. Seems to wind out a bit and go into 2nd a little rough. Does anyone know if this normal or what? Took to Frankle Acura in Timonium and they said other then needing to turn the rotors & brakes the car is fine, but know from experience can't always trust what the dealership says. Any help would be appreciated.
Old Jun 24, 2010 | 02:49 PM
princelybug's Avatar
LIST/RAMEN/WING MAHSTA 짱
Have you ever replaced the ATF?
Old Jun 24, 2010 | 02:50 PM
eppy26's Avatar
Not yet. Dealership said it didn't need it, but know with my other honda's that it is due. Why?
Old Jun 24, 2010 | 02:57 PM
The stealer is right in that Acura doesn't "recommend" it, but you needed it @ 10k. I'd drain/fill it 3x, as it tells you to do on this link:
https://acurazine.com/forums/3g-tl-2004-2008-93/rr-journals-atf-drain-refill-3g-garage-c-012-a-556044/
You might also want to look into replacing your pressure switches as well: http://www.acura-cl.com/forums/showthread.php?t=729149
Old Jun 25, 2010 | 09:12 AM
eppy26's Avatar
Thanks for the info, will take your advice and get it done. Just want to ensure the tranny is in top shape before warranty is up. Love Honda products, but have always been a little wary due to the trans in my 99 Accord Coupe having some problems. How does your TL feel when shifting from 1st to 2nd gear. Smooth or does it seem to wind out a bit?
Old Jun 25, 2010 | 11:19 AM
Your welcome. I drive a stick-shift, so it's different then your situation. Although we have issues of our own, mine shifts like butter!
Old Jun 30, 2010 | 01:25 PM
eppy26's Avatar
Sorry for taking so long in getting back, but thanks for the help and the type S 6MT is definitely sweet. Shout at ya soon.
MetalGearTypeS
Aug 29, 2016 08:28 PM
knight rider
Mar 4, 2016 08:59 AM
joflewbyu2
Oct 8, 2015 11:16 AM
Thuneau
Oct 3, 2015 04:19 PM
ROSSARONIE
Sep 22, 2015 11:46 AM
