2007 TL Leaking Shock??
Old Jul 7, 2016 | 10:22 AM
ROWDY621's Avatar
Hi all got a quick question. Recently, I have noticed a small leak of seems like an oily liquid coming from the drivers side rear wheel area. I get down to check it out and I find that the bottom of my shock looks wet and hence the leaking. I have taken a pic of it could you guys tell me if my shock is getting ready to blow, or is it something else? Any info is appreciated.
Thanks in Advance.
Old Jul 7, 2016 | 10:25 AM
a leaking shock is a blown shock
Old Jul 7, 2016 | 10:30 AM
Mileage information could be relevant here...
Old Jul 7, 2016 | 10:34 AM
meh, as soon as a shock absorber recieves load, it has the chance to blow.
it is hydraulic, after all.
ROWDY621's Avatar
Sorry, 2007 TL with roughly 89K.
Old Jul 7, 2016 | 10:35 AM
Ive had hydraulic car jacks fail on me....and thats where jack stands come into play.
Old Jul 7, 2016 | 10:36 AM
brand new acura's, specifically the mdx go back to warranty because of blown shocks...
Old Jul 7, 2016 | 10:37 AM
a leaking shock is a blown shock absorber
Old Jul 7, 2016 | 10:38 AM
ROWDY621's Avatar
so is that probably what it is? How much would something like this cost, and do you replace all 4 shocks, or just the 1?
you're right justin
time to get some coilovers! replace em all at once.
or least the front pair
Old Jul 7, 2016 | 10:39 AM
the answer is replace the blown shock.
if it were me, i'd replace all 4....however, if budget is tight, you can get away with just doing the broken one.
Old Jul 7, 2016 | 10:40 AM
Old Jul 7, 2016 | 10:41 AM
Old Jul 7, 2016 | 10:59 AM
truonghthe's Avatar
replace shock at least in pair if you are in budget, if not I would go for all four.
Old Jul 7, 2016 | 11:12 AM
csmeance's Avatar
Thanks in Advance.
Koni Yellows are an excellent replacement for the factory shocks! Lifetime warranty for the person purchasing the koni's as well. For a bit less than the Koni shocks (only shocks), you can buy the Tein SA Coilover kit that is stiffer than the factory suspension but can be adjusted for more comfort, lowers the car and saves about $200. You can also go with KYB replacements from rockauto that are going to be cheaper.
I replaced the factory shocks on my TL with 140K and it wasn't that bad of a job to do as long as I had the Impact gun to remove some bolts.
Old Jul 7, 2016 | 04:03 PM
WDPanda's Avatar
+1
I would go with OEM as well. They last quite a long time and how can you go wrong with OEM? I hate aftermarket anything, especially critical components.
Flipster23
Norcal
262
May 4, 2023 02:47 PM
EE4Life
Dec 20, 2022 05:16 PM
EE4Life
Mar 12, 2020 07:29 PM
EE4Life
May 14, 2016 07:14 AM
Hau_nguyen91
Mar 25, 2016 10:39 PM
