Acura TL is overheating!!
Old May 11, 2016 | 06:28 PM
acura1812's Avatar
I have a 2005 acura tl and it's been overheating. I've recently replaced my radiator thinking it was that. It's been a week that it wasn't heating up but now it starting reaching H again. My mechanic wants to take out the thermostat since he says that it's not really needed in Florida. Is this true?? What could be causing it to overheat? also, ive noticed that whenever i turn on the a/c it starts to overheat very fast.
Old May 11, 2016 | 07:53 PM
teh CL's Avatar
get a new mechanic
Old May 11, 2016 | 09:01 PM
Originally Posted by teh CL
get a new mechanic
Lost all credibility at "take out thermostat".
Might as well take off the hood too to lower temps..
Old May 11, 2016 | 11:19 PM
csmeance's Avatar
Are you loosing coolant? thermostat is most def needed no matter what car you have. If the thermostat is stuck in the closed position it could explain why your car is overheating
Old May 12, 2016 | 06:22 AM
many of number of things can make a car over heat.
clogged radiator will over heat a car.
no coolant will over heat a car.
(probably has to be said - but if radiator is leaking, you'll have no coolant resulting in a overheated car. )
if head gasket is bad and coolant goes away, then yep you guessed it, will over heat your car.
if water pump fails and coolant leaks, then yup another over heated car......
if thermostat fails = overheated car.
Old May 12, 2016 | 07:53 AM
flyromeo3's Avatar
Did you bleed the system properly after replacing the radiator?
Also, please smack your "mechanic".
Old May 14, 2016 | 05:42 PM
Whovain's Avatar
Registered. Nothing more.
My sisters TL overheated on the freeway. She got it fixed and told me that it was the "Heater Core Valve".
Old Jul 8, 2016 | 11:41 AM
RJS Aviation's Avatar
I just posted about Fan relays in my 2006 TL. Common problem and easy fix. You might check out my post.
The title is:
2006 Acura TL Overheating problem could kill your engine, quick fix
Flipster23
Norcal
262
May 4, 2023 02:47 PM
prepreludesh
May 14, 2016 02:44 PM
1789
Apr 13, 2016 07:27 AM
BoricuaTL
Apr 8, 2016 01:08 PM
Hau_nguyen91
Mar 25, 2016 10:39 PM
