2007 Acura TL Radiator Support Question
My 07 TL was in an accident and the Radiator support was bent and therefore needs replacing.
This might be a newbie question, but is the Radiator support a bolt on/bolt off or does it require drilling/welding?
its bolted on. as long as the rest of your frame isn't damaged, buying a new radiator support will be sufficient. if other parts were damaged, the radiator support may not bolt back on correctly.
to remove the radiator support you just take out the bolts on each side and lift up.
