2007 Acura TL base
Old Jun 16, 2024 | 11:52 AM
quigley2003's Avatar
2007 Acura TL base
I have a 2007 Acura TL base with Navi it has 132500 miles and maybe I’m just tripping but when I start it up the low oil pressure light stays on for a less then a second don’t know if u just started doing that or I never payed attention the oil level is good check it once a week it doesn’t burn oil or leak oil TL runs great no issues thanks
Old Jun 17, 2024 | 11:32 AM
twokexlv6coupe's Avatar
Are you in the deep south, using a lighter weight oil? 20W-50, for instance?
Double check with a mechanical oil pressure gage available @ AutoZone, threaded in place of the OEM oil pressure switch. IIRC the oil pressure light comes on <10psi, which should be the pressure at warm idle, not cold.
If you do indeed only have 10psi at cold idle, you could potentially have a VERY serious problem with a worn out oil pump, excessive clearance between your bearings, or another serious issue.
Old Jun 17, 2024 | 11:54 AM
I’m in Colorado
File Type: mov
quigley2003
Mar 13, 2024 10:45 PM
Eric Turner
May 2, 2023 03:51 PM
starklassik
Oct 3, 2019 12:20 PM
Cody Otten
Jan 31, 2017 05:24 PM
iisylentii
2G CL Problems & Fixes
Aug 30, 2012 11:51 PM
