2006-TL Hard downshifting
Old Aug 7, 2008 | 02:01 PM
Acuralin's Avatar
Hi all,
Only when driving above 75 mph occurs.
I did a little experiment, and at 75mph I pressed the gas just a bit, then I saw the rpm went high which means it downshifted but it was very very smootly, almost fell it. But then (after 1-2 seconds) I push the gas harder and it will downshift again (into the third gear) and this time quite hard, like a bad transmition.
At 75mph rpm is as below:
5'th gear - 3100
4'th gear - 3500
3'th gear - 3900 (this is the faulty gear at downshifting)
I am not pushing it too often, hence I am not sure if this issue was there before.
Could you guys tell me if it happens the same with your Tls?
Thanks.
Catalin
Mike Pilipenko
Mar 26, 2024 09:21 PM
SidhuSaaB
May 30, 2020 12:40 AM
mlody
Dec 4, 2019 02:11 PM
08KBP_VA
Oct 22, 2019 01:55 PM
xsilverhawkx
Oct 5, 2015 11:00 AM
