2006 TL blown transmission
What's the fastest way to remove the Tranny but I also don't wanna drop the subframe. Can it be done without removing the subframe or at least droppin the subframe on the drivers side only. Thx acurazine members
Don't think you can drop it only on one side.
I'm gonna take the engine and tranny out from the top it look to be a lot less work and would make bolting a tranny up easy. Thx for the reply.
I dont believe you can take the engine and trans bolted up together out the top. But be my guest and try.
Removal of the subframe is mandatory to take out the trans from the bottom.
It can be removed from the top u have to remove the oil filter housing a it gives the room needed to take them out together from the top.
Did you complete this? I am getting ready to swap in a reman trans. want to know what I'm getting into. Also since i need to do a timing belt simultaneously, wondering if your method would be easier considering that labor as well.
tjmoneybags (06-01-2016)
Thanks, I watched all 4 videos. I think that helped a lot. He mentioned you could go up or down with it but that it looked easier in that case to go up due to the car being a MT. I am still debating dropping out the bottom and wish there were pics of that as well. I've just only worked on V8 RWD cars, so curious what to expect. I have access to a nice shop with a lift. any advice helps.
Yes I did took the engine and Tranny out from the top. Yes it was easier having everything on the ground todo whatever I needed done. If I was you I would pull them out together from the top.
ogiewon
03-18-2016 11:55 PM
