2006 TL blown transmission
Old Apr 13, 2016 | 04:14 PM
19moe78's Avatar
7th Gear
What's the fastest way to remove the Tranny but I also don't wanna drop the subframe. Can it be done without removing the subframe or at least droppin the subframe on the drivers side only. Thx acurazine members
Old Apr 13, 2016 | 11:47 PM
csmeance's Avatar
Dropping the subframe is th easiest way to do it. Draw the outline of where it is on the car before removal with a sharpie or wax marker. Remove the subframe and when reinstalling look at the guide marks you made earlier.
Don't think you can drop it only on one side.
Old Apr 14, 2016 | 01:10 AM
19moe78's Avatar
7th Gear
I'm gonna take the engine and tranny out from the top it look to be a lot less work and would make bolting a tranny up easy. Thx for the reply.
Old Apr 19, 2016 | 01:17 PM
bassix67's Avatar
6th Gear
I'm in the middle of swapping my trans. Taking the subframe is the easiest.
Old Apr 19, 2016 | 02:53 PM
musiclevelz5's Avatar
I dont believe you can take the engine and trans bolted up together out the top. But be my guest and try.
Removal of the subframe is mandatory to take out the trans from the bottom.
Old Apr 25, 2016 | 01:24 AM
19moe78's Avatar
7th Gear
It can be removed from the top u have to remove the oil filter housing a it gives the room needed to take them out together from the top.
Old May 27, 2016 | 12:23 PM
tjmoneybags's Avatar
Did you complete this? I am getting ready to swap in a reman trans. want to know what I'm getting into. Also since i need to do a timing belt simultaneously, wondering if your method would be easier considering that labor as well.
Old May 27, 2016 | 07:59 PM
flyromeo3's Avatar
Which this video. It shows EricTheCarGuy pulling the engine from top.
There are 4 parts to it.
Old Jun 1, 2016 | 10:45 PM
Thanks, I watched all 4 videos. I think that helped a lot. He mentioned you could go up or down with it but that it looked easier in that case to go up due to the car being a MT. I am still debating dropping out the bottom and wish there were pics of that as well. I've just only worked on V8 RWD cars, so curious what to expect. I have access to a nice shop with a lift. any advice helps.
Old Jun 8, 2016 | 11:12 AM
19moe78's Avatar
7th Gear
Yes I did took the engine and Tranny out from the top. Yes it was easier having everything on the ground todo whatever I needed done. If I was you I would pull them out together from the top.
Flipster23
Norcal
262
May 4, 2023 02:47 PM
dwb993
Jul 30, 2016 02:59 PM
wfan111
Jun 24, 2016 11:29 AM
Evilocity
Apr 22, 2016 09:33 AM
ogiewon
Mar 18, 2016 11:55 PM
