2006 TL 6 speed manual body control module?
I have been having a problem with my passengers side front door lock. If I operate from the driver's side everything works normal. If I touch the passenger control to unlock lock it freezes up and won't move. I have to go back and forth for like 5 mins lock unlock and trying to pull the lock pin up to get it to unlock. I had a few things dned at the Honda dealer a few weeks ago and asked them to diagnose. They told me it was the door lock actuator. I wasn't about to pay their price to replace. I have life time alignments through firestone so I dropped the car off for a free alignment and to change the lock actuator. They replaced the actuator and it did the exact same thing. The passenger locks but won't unlock. The bench tested the old one and showed me that it works perfectly fine. So they took the new one out and didn't charge me for it. They went to diagnose it. They went through the diagrams and said the computer isn't sending power to unlock it. They told me my body control module is bad and that they think it's in the ECU so I have to take it to the dealer. Only the dealer can program a new ecu to your car they said. Here's my questions. Does this sound right? Is there a separate body control module on 2006 TL 6 speed manual? Also when I bought the car the guy said he ran hondata on it to make vtec click in at 4 and a half thousand rpms which it does. I though you can only run hondata in 07 08. Does that mean I have a 07 08 ecu? Also where's is the ecu or if there is a body control module where is that?
Registered Bunny
You're saying if you operate the door lock from driver side, everything is fine (the passenger door unlocks?), but if you're operating from the passenger side, then the passenger side door lock gets stuck?
1) Definitely not the actuator, Honda dealer is dumb and Firestone is right about that.
2) Did Firestone test the switch? That would be the first step in diagnosing. Then door multiplex. Until that is done, you could be messing with things you shouldn't be.
Check service manual to see how to test.
AcuFrizz
02-19-2018 06:46 AM
workTL
05-07-2015 10:39 PM
rakibr
05-07-2013 12:06 PM
meazz1
1G TL (1996-1998)
04-19-2012 10:45 AM
