2006 MT Clutch Slipping?
2006 6 speed MT. In 5th or 6th, steeping on the gas pedal causes an immediate increase in RPM but not speed. Then RPM drops to match speed and car accelerates. Sounds like the first signs of a clutch slipping?
there are real world test; most of them destroy your clutch tho.
the real indicator is that your RPMS go up but not speed.
that is the sign of a slipping clutch.
LUK makes the stock clutch.
you can find the stock clutch for 100 dollars or a little less.
try rockauto.com or ebay.
fly wheel is a little bit more pricey from those same sources I gave you, but still will be cheaper than the dealer.
then you will need an independent shop to help you install your clutch kit.
a shop did it for me for $400 + cost of clutch kit.
at the time, I didnt know about ebay or rockauto...and ended up paying 350 for the stock clutch kit at acuraoemparts.com
however; it is significantly cheaper if you source the LUK clutch kit from somewhere else.
Thanks - would rather the dealer be responsible for it. Issues and they will have to fix it. And I don't have a trusted local/independent mechanic to use. I do just about everything else that I can myself.
$2500 still seems very pricey for a clutch/PP replacement. Even if they are charging list price for parts it sounds like a $1500 labor cost. A good indy will do that for a fraction.
Also, consider upgrading the front lower sway bar while you have the subframe out...maybe the lower control arm bushings...make a list of all the stuff that won't add barely any labor while it's out.
Dealership mind-fucking at its best.
Me? I prefer dealer maintenance...although I try to take it to Honda instead of Acura for pricing as well as convenience since the Honda dealer is less than 5 miles from my house. It is also nice to just walk in, drop my keys, grab a key to the loaner, and leave. There is a price to pay for convenience. Just a matter of being aware of that cost and accepting it.
SidhuSaaB
May 30, 2020 12:40 AM
Jul 16, 2017 07:33 AM
sounded like that to me too.
