2006 Acura TL transmission problem
Old Mar 17, 2018 | 10:47 AM
Phillip1313's Avatar
6th Gear
How’s it goin everyone I’m new to the site, I have a 2006 Acura TL 107k Miles automatic, well recently I’ve noticed a hard lunge/bang forward when the car shifts first to second but does not do it under low rpms, all the motor mounts and transmission mounts are new and every other gear shifts smoothly no problems. Any help would be great so I could try to fix this if it’s something that I could do..
thank you
Old Mar 17, 2018 | 11:47 AM
horseshoez's Avatar
Latent car nut
Have you serviced the transmission and the pressure switches?
Old Mar 17, 2018 | 02:16 PM
6th Gear
Went to Acura got the transmission fluid changed didn’t check anything else, what else should I change or do I tried finding stuff about the first to second problem I couldn’t find anything anywhere it’s a hard bang. On high rmps but not on very low rmps
Old Mar 17, 2018 | 05:45 PM
restron's Avatar
BANNED
never ever change transmission oil , thats ehy BMW transitions are sealed and they don't recommend ever changing that oul
i had same issues on my acura, change transmission fluid transmission GONE
Old Mar 17, 2018 | 05:57 PM
horseshoez's Avatar
Latent car nut
This is very-VERY bad advice for Honda and Acura transmissions; woe be it to anybody who follows @restron's advice.
Old Mar 17, 2018 | 06:11 PM
Jackass's Avatar
Ummm...this isn't a BMW forum, the OP doesn't have a BMW, nor is our transmissions sealed. Horrible advice....just horrible.
To the OP, is the bang because it the shift is delayed and it lunges when it finally engages? Or is it just because it is a high RPM shift? Are there any delays between the shifts? Or are they are all timed roughly the same. Most bangs during shifts will be bad mounts...however if there is a pause between gears and it finally grabs, that has the potential to be a tranny issue that may be improved with new fluid and possibly solenoids.
Old Mar 17, 2018 | 06:33 PM
restron's Avatar
BANNED
everytime i hear s failed tranmisison story , it always after transmission oil changed just like OP
Old Mar 17, 2018 | 07:26 PM
horseshoez's Avatar
Latent car nut
Clearly you do not understand how transmissions work or how ATF ages. Regarding transmissions failing shortly after a service, very frequently the owner detects an issue and hopes a quick ATF change will fix it. Said another way, the transmission would most likely have failed regardless of whether the ATF had been changed or not.
Old Mar 17, 2018 | 07:29 PM
restron's Avatar
BANNED
could be true, i drove 120k woth no trans fluid change and no problms
Old Mar 17, 2018 | 07:33 PM
horseshoez's Avatar
Latent car nut
I'm an engineer, and in our world we have a saying, "You cannot prove a positive with a negative."
Old Mar 17, 2018 | 07:35 PM
restron's Avatar
BANNED
If you have never changed the transmission fluid in your vehicle and have more than 100,000 miles on the odometer, should you change it now? mechanics suggesting you should just leave well alone if you aren't having shifting problems.
Old Mar 17, 2018 | 07:36 PM
horseshoez's Avatar
Latent car nut
Mechanics are often the source of some of the worst automotive advice know to man. So, who would you trust, a grease monkey or a highly trained Honda engineering team with decades of experience?
Old Mar 18, 2018 | 05:10 AM
6th Gear
It only does the bang between first and second gear every other year shifts perfect automatic transmission , it shifts at normal rpms just when if shifts first to second it’s like a bang kinda and lunges forward, all the trans mounts were changed same as engine mounts I need help this is my daily car any possible suggestions would be much appreciated thank you
Old Mar 18, 2018 | 12:09 PM
6th Gear
update: did the transmission flush yesterday drove it around was still banging bad yesterday , then today I took it for a drive and the problem was noticeably less but still was there a little anybody have any ideas
Old Mar 18, 2018 | 12:25 PM
horseshoez's Avatar
Latent car nut
As previously mentioned, have you replaced the 3rd and 4th gear Pressure Switches?
Old Mar 18, 2018 | 12:32 PM
6th Gear
I haven’t switched those just yet I was going to do it today do any parts stores have them like advanced auto or something ? Would those mess up the first into second shift ? Thank you for helping out
Old Mar 18, 2018 | 12:54 PM
horseshoez's Avatar
Latent car nut
Disclaimer, I am a manual transmission bigot, so my comments are strictly based upon what I've read here on this site.
The disclaimer out of the way, my understanding is the only two things you can really do for your transmission, short of repairing it or replacing it with a much improved unit from a 2006-2007 Honda Accord V6 (aka. the AV6 transmission), is to do the 3x3 fluid replacement and replace the 3rd and 4th gear pressure switches. If neither of those things helps your transmission, then most likely you're facing a transmission replacement of some sort. I suppose another long shot could be a partial axle failure on your car, but the symptoms don't really point that way.
Old Mar 18, 2018 | 01:27 PM
6th Gear
Not sure what else to do if them switches don’t work any other suggestions I could do ?
Old Mar 18, 2018 | 02:20 PM
horseshoez's Avatar
Latent car nut
If the switches don't work and the axles check out, the next place I'd go if I were you is here:
Old Mar 18, 2018 | 08:34 PM
EvilJoker's Avatar
All Around Klown
The 2nd to 3rd and 3rd to 4th switches will not affect his 1-2 shift. There 2 more pressure control switches that some people do not know about on top of the tranny. They have a weird name and I cant remember what they are called exactly. There are 2 and they are underneath a panel that has to be removed from the tranny to change them out. They are quite a bit more expensive than the other 2. If I can find the part again, I will post the link.
Old Mar 18, 2018 | 08:46 PM
EvilJoker's Avatar
All Around Klown
https://www.acuraoemparts.com/oem-pa...QtYXV0b21hdGlj
Old Dec 21, 2019 | 11:16 PM
Rony Marquez's Avatar
Hi, I have a 2006 Acura TL, I’m having transmission problems I have 104k miles, and just 2 days ago I changed the transmission fluid since I thought that was the problem, but now my car won’t even turn on, and I’m worried on what I should do, whenever it goes from first gear to second it has a hard twitch and also when I get on reverse it feels like the transmission falls!!
Old Dec 22, 2019 | 08:06 AM
horseshoez's Avatar
Latent car nut
I seriously doubt the transmission has anything to do with your car not being able to start. As for the transmission itself, do a search here on a 3x3 ATF change and swapping out the 3rd and 4th gear pressure switches.
Old Dec 22, 2019 | 12:32 PM
Yeah I think it might be my battery then, would I change the pressure switches for my 3rd and 4th gear or for my second??
8800honda
Dec 30, 2019 03:22 AM
Sdavis630
Oct 17, 2016 12:49 PM
amorri19
Apr 8, 2014 10:51 AM
kenny_powers
Aug 14, 2012 02:39 PM
