2006 acura tl not starting, tried everything
Recently I replaces my spark plug and ignition coil. When I pulled the spark plug out, a Helicoil came out with it and I did not notice, after driving for 10 minutes, i noticed it was misfiring like crazy and i pulled off to the side of the road and noticed that my ignition coil and sparked plug were blown out and burned up in cylinder 4.
The next monring, i went and got a new ignition coil, spark plug and Helicoil. put them all in and the ignition coil is sitting up about 1.5mm like it was before when the car was misfiring at random times.
I checked the fuses, tested the battery and the car has power and cranks but the car will not start.
Anyone had this issue or can figure out anything else that I can check out that might be causing the car not to start.
tlmane03
Jun 4, 2013 04:45 PM
