2005 TL manual shifting problem!
2005 TL Abyss Blue
I bought a 2005 Acura TL and it is a beautiful car that I love EXCEPT when shifting to 3rd gear there is a crunching sound and it may or may not always actually go into third the first try. Acura said they have heard other complaints about this but that it is "normal" for this 2-3rd gear synchro design. I am establishing a record with Acura customer hotline and have ordered the service bulletin from site: http://www-odi.nhtsa.dot.gov/home.cfm which everyone should scan before buying any car. Does anyone else have experience with the manual trans problem, let me know.
HMFIC
This has been discussed and the information you posted points to a TSB...
Make: ACURA Model: TL Year: 2004 Type: PASSENGER CAR Service Bulletin Number: 1205 NHTSA Item Number: 10018865 Summary Description: TRANSMISSION GRINDS AT SHIFTS, SKIP SHIFTING. *TT
GM synchromesh - friction modified cured my poor shifting.
2005 TL Abyss Blue
Sandie
2005 TL Abyss Blue
Sandie
2005 TL Abyss Blue
Originally Posted by stever627
yes. under warranty
Sandie
GM synchromesh, friction modified is transmission fluid from General Motors. Mostly all members who have changed their transmission fluid to this GM fluid swears by it. It has solved all their shifting problems including the 3rd gear problem.
If you're dealer is unwilling to swap it out for you, go to any qualified mechanic or do it yourself. It is fairly easy to do.
https://acurazine.com/forums/showthr...omesh+modified
Try this thread for starters.
2005 TL Abyss Blue
![Cool](https://acurazine.com/forums/images/icons/icon6.gif)
I have a 2005 Manual Trans. TL...and have had a horrible time with shifting in to 3rd gear; and at times trouble shifting in to 4th...just like so many others report on these forums. Acura even replaced the trans. once, and the problem did not go away. What they won't admit is that there is a design flaw. From what I've been told by some mechanics is that it probably is a Synchro problem. What Acura refused to do is tear down that first trans. and see what is wrong (Believe me...I asked them to...'never could get an answer if it was done / what the results were, if they did do it.). I don't think they want to know the truth...and they certainly didn't want to spend the extra money to do this. So...here we are...once again... The problems have not gone away. A "big cheese", at Acura, is supposed to contact me...but I anticipate a conflict. If the call doesn't go well, I will consider the "Lemon Law".
I just picked up an 05 6MT. I have trouble getting into third at least once every time I drive it. I took it in, but of course they said it drove normal. Honda/Acura came out with a new MTF (manual trans. fluid) that is supposed to help with this, and it's the only MTF they should be carrying right now. In the january 07 service news report, the first article details the introduction of this new fluid:
NOTE: This article applies to all M/T-equipped
Acura vehicles.
We've heard reports of clients complaining about
the M/T shifting stiffly or popping out of gear. In
each case, the M/T was using aftermarket MTF or
old Acura MTF. If you've got a vehicle in your
shop that fits this profile, try draining the MTF and
replacing it with new Acura Precision Crafted MTF
(P/N 08798-9031A). This new MTF offers better
overall shift quality in cold weather (especially in
freezing temperatures), and it's got better friction
reduction for improved fuel economy and longer
transmission life.
After filling the M/T with this new MTF, take a
10-mile test-drive around town so you can do a lot
of shifting. If you've still got this problem after
your test-drive, then it's time to do some
troubleshooting.
I am planning a fluid swap real soon since I'm really getting sick of this notchy third gear and grinding high-rpm up-shifts (in my 03 element too). I just haven't decided if I should get the new Honda/Acura MTF, or just go straight for the GM friction-modified stuff.
Acura vehicles.
transmission life.
troubleshooting.
Mike's Silver Bullet
I had the 3rd gear issue too, and the other gears weren't all that great, either.
Does the clutch feel different from other manual trans cars you have owned?
The clutch had to be replaced in mine at 18k, under warranty. I think the self-adjusting pressure plate failed, but I couldn't get Acura to fess up. Under this scenario, the clutch drags and the gears hang up when you shift; 3rd just happens to be the worst.
I haven't had the 3rd gear problem since the clutch replacement. However, they put the new Acura fluid in mine when they did the clutch, and it's only been about 1500 miles since then.
Rrrtl
To: 94eg and sandynmike...
Thanks for all the info.
'ready for this???... Acura has replaced the Clutch and Trans. once, already.....and...again....the car is back with them....The problem is happening with this "set" too. This is the third time in the last 6 months I've left the car with them ('actually two dealerships...After the first dealer couldn't fix it, they suggested I go to another one in the Miami area)... I'm telling you...it's a design flaw. Sandynmike...I thought it was the synchro's for the 3rd and 4th gear....but.... the "self-adjusting pressure plate" failure possibility... that you mentioned...sounds plausible! Yesterday, I talked with the "second in command" of maintenance...you could say, for South Florida... and sure enough... he says that the clutch is damaged again. (Hot Spots and wear). So.... this is their "Get out of jail free" card... They are trying to blame me for the wear. I know people say this and say that.. but... in all honesty, I believe I drive manuals fine... 'have been since 1985....and I had a '95 Honda Civic that I put 140,000 miles on; before the first clutch failed.
94eg... As for the new Acura Precision Crafted MTF (P/N 08798-9031A) fluid... I believe they (Acura) used that on the last "TRY"...but
I will confirm with them, next week.
Well... We'll see what happens! Thanks, again!
RRRTL
RRRTL
A reminder to all MT drivers that sitting with foot on clutch in traffic or at lights will cause extreme wear on the clutch parts
You can shift gentle and not be a lead foot and still do those other things and trash the parts
On a side note, I always sit at a stop with the car in neutral and the clutch pedal out, and always recommend people do the same. I'm just anal that way...
![Wink](https://acurazine.com/forums/images/smilies/wink.gif)
'ready for this???... Acura has replaced the Clutch and Trans. once, already.....and...again....the car is back with them....The problem is happening with this "set" too. ...
RRRTL
RRRTL
https://acurazine.com/forums/showthr...ht=clutch+tool
If it was like mine, the clutch caught too close to the floor, and the friction zone was large. I think those are the symptoms of the bad pressure plate.
Good Luck.
I had Acura put their new and improved MTF. The shifting was much better but the notchy 3rd gear issue returned in its full glory in less than a month . I put in the GM Synchromesh and, three months later, the shifting is still flawless. I had a local mechanic put it in for me - he only charged me $20 for labor too
handsom-hustla
11-13-2015 05:04 PM
Mike Bertram
09-10-2015 09:27 AM
HeloDown
09-08-2015 06:51 PM
