2005 TL Fuel Door Lever Locked?
Old Nov 18, 2011 | 12:36 PM
Dominus's Avatar
4th Gear
I have a weird issue. My Fuel door lever doesn't budge when parked outside in the cold. It's like its locked in place. However, if i were to park in a garage, the next morning the Lever will work, and I can access my gas tank.
I know its because of the cold weather (-5 degrees Celcius), but what is actually happening that causes that fuel lever to lock up? Anyone else have this issue in a 04-08 TL?
Old Nov 18, 2011 | 12:37 PM
ice?
take a look at the mechanism. play with it. see whats going on.
Old Nov 18, 2011 | 12:46 PM
Dominus's Avatar
4th Gear
There is no ice in or around the lever itself (the one by the door sill on the drivers side), and there is no ice on the actual fuel door.
My guess its something mechanical or eletronical underneath the car that connects the two....
Old Nov 18, 2011 | 12:47 PM
Dominus's Avatar
4th Gear
Also, the lever won't even budge.
When it works normally, you know how you can pull that level about half way and not have the fuel door open? The fuel door only opens if you pull that lever all the way up.
Right now the lever won't even budge, when parked in the cold.
SidhuSaaB
May 30, 2020 12:40 AM
agupta3224
May 23, 2017 08:30 AM
RobbDizzle
Oct 15, 2015 11:16 AM
joflewbyu2
Oct 8, 2015 11:16 AM
95oRANGEcRUSH
Sep 25, 2015 12:50 PM
