'06 TL 6MT Suggestions?
Old Nov 4, 2011 | 01:31 AM
D-JET's Avatar
8th Gear
Hello. I'm new to this forum. To those of you with 6MT, what problems do you guys have and what should I look out for when buying the car? I'm looking to get an 06 w/ 6MT. Thanks for any input. Cheers.
Old Nov 4, 2011 | 02:09 AM
jungy4's Avatar
I bought my 06 6MT about 2 years ago with 35k miles. It's at 61k right now. Other than some little things, it's been pretty solid mechanically.
The only mechanal problem I had was front Brembo breaks squealing with light application. My dealer replaced the pads under warranty and the noise was gone.
You might get various interior rattles but they are pretty easy fix once you locate them.
A lot of people with the 3rd gear pop out issue would recommend replacing the transmission fluid with the GM one. I haven't had that issue yet.
Congrats on finding a rare car.
Old Nov 4, 2011 | 10:35 AM
ohsixMTee's Avatar
Early Shifter
IMO the GM fluid won't just fix the 3rd gear issue but will improve shifting overall. I didn't have an issue with it either but had the GM fluid installed and it made a dramatic improvement and allows you to get into gears much much better.
I think 06 is a very safe to buy year, the car was already out for 2 years so Acura had some time to improve things and work out bugs. The TPMS monitor is convenient as well, it doesn't take much effort to check it manually but I'd much rather push a button. lol
Old Nov 4, 2011 | 10:52 AM
ez12a's Avatar
the overexplainer
The only thing specific to the 6MT would be the 3rd gear, and maybe a click in the clutch pedal travel. Other than that it's just like any other TL.
Old Nov 4, 2011 | 06:18 PM
D-JET's Avatar
8th Gear
Thanks guys. Any other insights?
Old Nov 5, 2011 | 12:23 AM
D-JET's Avatar
8th Gear
Also, I'm debating to get either an 06 TSX 6MT or an 06 TL 6MT... What you guys think I should get and why?
Old Nov 5, 2011 | 01:33 AM
jungy4's Avatar
Have you found these cars or are those what you are looking for? If you have, can you link them? 6MT is very hard to find.
TSX would give you better handling and fuel economy, but TL will have smoother ride and faster performance.....
Old Nov 5, 2011 | 01:39 AM
D-JET's Avatar
8th Gear
You're right. It's very hard to find a low mileage 6MT TL or TSX. I saw only 1 of each, but it's either high mileage or asking for too much. I usually use cars.com.
Any other insights on should I get a TSX or TL?
Old Nov 5, 2011 | 12:15 PM
jungy4's Avatar
Hmm, TL's engines require timing belt change around 100k miles which can be pricey.
TSX has fold down rear seat that I wish I had sometimes.
Old Nov 5, 2011 | 01:12 PM
nj2pa2nc's Avatar
it's a car-drive it
Love my 06 6MT tsx. Great car-recommend it. No problem with 3rd gear pop-out and it has Honda MTF. It was replaced at 100K miles.
Old Nov 18, 2011 | 02:24 AM
robocam's Avatar
Is that click specific to the 06s? Any way to get rid of it? I don't notice it anymore, but it'd be nice to get rid of it.
The GM transmission fluid got rid of my 3rd gear problem.
One thing to note. Don't over rev your engine (by accidentally shifting into 1st instead of 3rd). The pistons can hit your valves and bend them. Unfortunately, I think I'm in that situation right now, and I'm still trying to decide how to deal with it (leave it as is or have it repaired). I wish they designed the engine so that this couldn't happen. The pistons have recesses in them, but the valves still hit. I don't get it.
Old Nov 18, 2011 | 07:22 AM
SouthernBoy's Avatar
Registered Member
This is called valve float and is due to the valve springs not having enough time to return the valves to their seats when closing because the engine speed is too great.
Old Nov 18, 2011 | 10:19 AM
ez12a's Avatar
the overexplainer
I believe you can either grease the pedal assembly or replace the master clutch cylinder for the clicking. It's not specific to 06s, just any 6MT TL really.
Old Nov 18, 2011 | 01:30 PM
bpalmeryat's Avatar
I have a '06 TL 6MT and the only issue I have had is the transmission popping out of third gear when I first put it into gear. I bought mine at Carmax and convinced them of the problem and they replaced it for free (about a $1800 fix). I also have hear the clicking noise a time or two, but it bothers my Wife more than I.
One interesting note about this car, I work for a tier one supplier that makes the front engine cradle for the TL and one of the options that we made that year was a China model, it had an extra weld nut for a hay guard. Apparently, the Chinese would utilize the vehicle to roll over their hay in the road to flatten it out, in the earlier models the hay would roll into the engine compartment and catch fire.
TypeS860
Jan 10, 2026 11:11 AM
4drviper
Apr 23, 2025 07:13 PM
baelim
May 10, 2018 09:53 AM
kb1rl
Sep 30, 2015 10:17 AM
stogie1020
Cameras & Photography
17
Sep 30, 2015 01:34 AM
