2005 TL engine compartment issue
Old Nov 3, 2014 | 01:07 PM
Shotgiver's Avatar
4th Gear
What is this part here? Looks broken. Could this be causing a thud sound with every bump in the road? Engine mount?
Old Nov 3, 2014 | 01:09 PM
dezymond's Avatar
Yup looks like an engine mount and that sucker is broken.
Side engine mount.
it is indeed broken.
and it could be the source of the sound you're hearing as it holds the engine in place.
Old Nov 3, 2014 | 01:12 PM
Acura Parts @ AcuraOEMparts.com - Genuine Acura OEM Parts from Delray Acura
Part #50820-SEP-A21
Old Nov 3, 2014 | 01:27 PM
paperboy42190's Avatar
^+1
Old Nov 3, 2014 | 04:09 PM
Shotgiver's Avatar
4th Gear
Is this an easy weekend job to do? I've replaced the knock sensor before on the car so I'm somewhat decent at working on cars. What am I looking at out of pocket vs having the dealership do it?
Thanks for the fast replies, everyone!
Old Nov 3, 2014 | 04:47 PM
Jackass's Avatar
Very easy to change. It took me about 30 minutes to do and that included finding my socket set. Once the tools were rounded up, this should be less than 15 minutes to replace.
Old Nov 3, 2014 | 05:04 PM
TacoBello's Avatar
Nonsense. Throw in a couple beers and it's easily a 45 minute job
Old Nov 3, 2014 | 05:31 PM
Shotgiver's Avatar
4th Gear
Thank you.
Did you have to do anything with the engine or was it just a part swap. Curios if I need to lift the engine a bit and if any disconnecting is required
Please advise
Old Nov 4, 2014 | 07:44 AM
Originally Posted by Shotgiver
Thank you.
Please advise
as long as the front engine mount isnt broken, as it holds it in place up high enough for the side mount.
if you do come across the engine slumping down enough where you cant get the side mount in; use a jack and a piece of wood to prop against the oil pan.
lift slightly to where the side mount aligns.
Old Nov 5, 2014 | 10:42 AM
YeuEmMaiMai's Avatar
Might as well replace the front one and trans mount while you are at it...
Old Nov 5, 2014 | 07:21 PM
Shotgiver's Avatar
4th Gear
yeah. I plan on trading the car in to a dealership pretty soon though so i dont want to do any expenses extra. plus i dont want to put my mechanic through too much (my dad lol)
handsom-hustla
Nov 13, 2015 05:04 PM
carz0159
Sep 20, 2015 06:11 PM
whitesoxsfan12
Sep 7, 2015 04:07 PM
