2004 TL Warning light VSA and Exclamation Help please!!
I have a 2004 Acura TL I just had new wheel bearings and compliance bushings installed plus after market abs sensors. Started driving it and ended up with an ABS Light, Brake Light, VSA Light, and the exclamation point. Great four codes.. Come to find out the wheel bearings were installed backwards with the magnetic pickup for the ABS on the outside. Took it back to the shop they put new bearings in the right way. Now I have the dam exclamation point still and after driving for about 500ft the VSA light kicks on as well.. I have checked fuses and the switch. Is there someway to clear the code or what can I try.. Really don't want to take it to the Acura Stealership!! Thanks guys
Stay Out Of the Left Lane
You might want to go to Autozone or some place like that where you can get the codes pulled/read. This and/or go back to the place where you had all the work done and get them to sort it out as I'm assuming you weren't having these issues beforehand.
mada51589
Jan 9, 2025 04:40 PM
rockyboy
Jan 25, 2016 06:00 PM
Skirmich
Sep 15, 2015 06:41 PM
