2004 TL manual Moaning noise!(Plz Read!)
Old Jul 13, 2013 | 03:23 PM
fresnoacura's Avatar
3rd Gear
Exclamation 2004 TL manual Moaning noise!(Plz Read!)
I got 2004 TL with six-speed with 101k on it.
She rides like a silk but she has one problem.
When i turn steering more than 180 degrees and let go clutch with 1st gear,
it starts to moaning....(low tone). And i already did O-ring replacement
recently.
Anyone has same problem?
Old Jul 13, 2013 | 07:22 PM
Vlad_Type_S's Avatar
Registered Bike Offender
How about the P/S fluid? Mine moaned and then I changed the fluid and it's been fine for over a year now.
Old Jul 14, 2013 | 03:39 AM
3rd Gear
I already refilled but not replace them all...
it keeps moaning...
Any idea? btw Thank you!
Old Jul 14, 2013 | 06:06 AM
^there's an O-ring that goes bad in the power steering pump thingy
Old Jul 14, 2013 | 02:05 PM
It sounds like he already replaced the o-ring.
OP, check out this thread. Do this procedure and then see if it still moans. I used regular Acura PS fluid.
https://acurazine.com/forums/3g-tl-2004-2008-93/104-diy-power-steering-fluid-flush-761094/
Old Jul 15, 2013 | 11:31 AM
3rd Gear
^ Ill try this soon. Its basically just flushing fluid..
Old Jul 16, 2013 | 02:38 PM
Exactly. I have some level of OCD, and since this is such an infrequent maintenance item, I like to refill the reservoir with clean stuff and pass it through a second time to collect any leftovers from the first drain. This isn't required, but it makes my crazy brain more satisfied knowing that some additional old stuff was removed.
Old Jul 17, 2013 | 06:28 AM
Project_CLean's Avatar
MMkay.
tonio
Feb 5, 2019 05:43 PM
OculiAquilae
Nov 19, 2018 02:24 PM
jamestheunderdog
Jul 19, 2016 07:58 PM
snorf
Sep 17, 2015 10:04 PM
PortlandRL
Sep 14, 2015 12:01 PM
