2004 TL intermittently loss of power
Old Nov 16, 2021 | 12:48 PM
Jayproductivo's Avatar
All of you ACURA TL HEADS with knowledge I need your opinion.
2004 Acura TL couple months ago popped a P0685 code. After looking it up on ALLDATA it gave me all the possibilities of what it can be so I began process of elimination. The car intermittently doesn’t want to start. also, while driving the car stalls like loses complete power and does a kick back when it does get power back. I have replaced everything electrical you can possibly imagine down to the starter for it’s not starting issues. Alternator, Battery, unplugged the HFL, looked for parasitic draw with no avail. I been testing wires left to right and no signs of anything. I say again this is intermittently. Oh I took it to the dealer and because it wasn’t a persistent issue they wanted to replace the alternator to start from there but I had already done that.
Has anyone ever had this problem? If so, please tell me what did you find the problem to be and how did you fix it?
Old Nov 16, 2021 | 01:01 PM
NBP04TL4ME's Avatar
Stay Out Of the Left Lane
A number of folks have posted here on Azine about this DTC coming up.
https://www.google.com/search?q=acur...4dUDCA4&uact=5
Old Nov 16, 2021 | 01:15 PM
ive done everything it has required me to do based on ALLDATA. The car seems to still intermittently do the loss of power
Old Nov 17, 2021 | 11:12 AM
Jackass's Avatar
I bet your battery clamp and/or main cable off the battery are failing. If the entire car loses electrical power, that is where I would start.
Old Nov 17, 2021 | 12:04 PM
Found it!!!
Hey everyone In case anyone has this similar problem. I finally found the culprit to the problem. It turns out to be a BAD ENGINE GROUND. Screw looks like it was stripped and loosened itself through time and was making the ground wiggle and every time it did it would make the car lose power. It’s about damn time lmao thank you all for real
Old Nov 17, 2021 | 12:12 PM
NBP04TL4ME's Avatar
I was going to respond to @Jackass response and suggest the potential for internal corrosion of one the battery cables. One or two other members have had that issue either hidden within the cable itself or at the opposite end of the cable (away from the battery). You still may want to feel and squeeze along the length of the cables to make sure that hasn't started in addition to what you found.
Old Nov 17, 2021 | 12:44 PM
will do brother I truly appreciate the responses 🤙🏾🙌🏽🙌🏽
Old Nov 26, 2021 | 10:07 PM
comkb's Avatar
i guess there are different symptoms. my ground wiggled its way loose during a drive but it drove normally until i parked, then i lost all power obviously. has never stalled while driving for some reason.
Old Nov 26, 2021 | 10:26 PM
yes brother I guess some vehicles react differently. But it ended up working out.
jleew540
Feb 7, 2014 08:51 PM
Manimal_Forever
Sep 18, 2012 12:58 PM
kdogtooth
Jan 26, 2012 05:55 PM
kristenacura
Sep 15, 2011 09:30 PM
dwyatt_08
Nov 6, 2009 09:15 PM
