2004 TL Hissing noise loss of power
Old Mar 6, 2014 | 10:50 PM
jar032's Avatar
9th Gear
I have an 04 tl that is making a hissing noise under acceleration and feels sluggish. it feels like it wont rev past 4000 rpms..
I already replaced air temp sensor..
Could it be clogged catalytic converters??
any help would be appreciated
Old Mar 7, 2014 | 07:42 AM
Do you have a check engine light on?
Old Mar 7, 2014 | 09:28 AM
EvilVirus's Avatar
^ +1
Does it idle abnormally? Have you check you hoses? Also if you have a stock intake, check the tubing to see if there are any tears.
Old Mar 7, 2014 | 02:42 PM
jar032's Avatar
9th Gear
No check engine light.. it idles rough when could and smells like fuel
Old Mar 7, 2014 | 03:43 PM
ZOMGVTEK's Avatar
With the engine at idle, unplug each coil pack separately and listen to the engine. You should notice unplugging each plug makes the car idle worse. If you get to one cylinder that does nothing, find out why.
Old Mar 7, 2014 | 03:51 PM
nfnsquared's Avatar
Snakes on a TL??
Old Mar 8, 2014 | 03:32 PM
jar032's Avatar
9th Gear
i unplugged each coil every one made the engine idle worse so all cylinders work
Old Mar 9, 2014 | 02:44 PM
Andrew Park's Avatar
JaHrOo
if you hear a hissing noise it might be a vacuum hose leak
Old Mar 9, 2014 | 08:52 PM
jar032's Avatar
9th Gear
i checked i dont see any vacuum hoses that are disconnected
jar032's Avatar
9th Gear
it only hisses under acceleration
Old Mar 14, 2014 | 01:38 AM
jar032's Avatar
9th Gear
Dec 7, 2020 05:39 PM
Feb 25, 2020 09:57 AM
saturno_v
Oct 28, 2015 06:57 PM
2012wagon
Sep 29, 2015 04:21 PM
2G-TL-Type-S-03
Sep 20, 2015 12:48 AM
