2004 TL Headlight bulb
Old Jun 20, 2009 | 03:35 PM
fxcarden's Avatar
My passenger side bulb went out. I looked around for instructions on replacing the bulb and all I could find was instructions to replace the entire assembly, which involves things like removing the bumper.
Please tell me I can just replace the bulb, and if someone could point me to the instructions for that, I would really appreciate it.
Old Jun 20, 2009 | 03:49 PM
218TL's Avatar
search......garage....
https://acurazine.com/forums/3g-tl-2004-2008-93/diy-hid-bulb-change-w-o-bumper-removal-3g-garage-g-004-a-598853/
Old Jul 8, 2009 | 02:14 PM
fxcarden's Avatar
Originally Posted by 218TL
Thanks.
I swapped the bulbs from side to side, and the "bad" bulb worked on the other side, and the "good" bulb did not work. So, that means it is either the igniter or the ballast.........correct ?.
Next question....is there an easy way to test these components to see which is the failing one.
Thanks again.
Old Jul 8, 2009 | 04:00 PM
csmeance's Avatar
Originally Posted by fxcarden
Thanks.
Thanks again.
The ballast and igniter are one piece if I'm not mistaken with the 3G TL.
Old Jul 8, 2009 | 05:59 PM
fxcarden's Avatar
My local dealer says they are separate parts each going for about $230.
Anybody ?
Old Jul 12, 2009 | 10:05 PM
shftl's Avatar
acuraoemparts.com:
http://www.acuraoemparts.com/delray/...All&vinsrch=no
What acuraoem calls the "igniter" the service manual calls "the socket." There is also the "control unit." Don't know which contains the ballast. They're both pretty pricey.
Old Jul 16, 2009 | 08:03 AM
fxcarden's Avatar
Well I wound up going to the dealer, and they said I need the INVERTER (BALLAST), and the IGNITER. Each part is about $220, and 2 hours labor. $650 for the whole job.
Jeez.
hashbrown
Feb 18, 2022 11:20 AM
Jul 16, 2017 07:33 AM
Mr.Tea
Oct 2, 2015 10:32 PM
mshipon
2G CL Problems & Fixes
Sep 28, 2015 12:14 PM
h22lude
Sep 27, 2015 06:22 PM
