2004 TL crank/no start
Old Mar 4, 2022 | 05:07 AM
Huskerboy7's Avatar
6th Gear
Hello, i have a 04 TL. Just replaced timing belt/water pump, thermostat, oil pump, and spark plugs. Drove great for 2 days and then i noticed the headlight was out so i went to replace it. I was waiting on a part to come in the mail and so i was going to pull the car up the driveway and as i went to move it the car cranked but would not start. Any ideas on things i need to check or fuses/relays to check. I would assume its probably not the timing due to it running great for 2 days. Also my obd reader is not working not as well. Any help would be greatly appreciated. Thank You
Old Mar 4, 2022 | 07:19 AM
DMZ's Avatar
DMZ
Head a da Family
Get hold of another OBD reader and find out what codes your system is throwing. AutoZone does OBD readings for free.
Old Mar 4, 2022 | 11:46 AM
twokexlv6coupe's Avatar
How's he gonna get it there if it doesn't start?
Can you hear the fuel pump priming?
Have someone else turn the key to the II position (right before cranking) while you stick your head inside the trunk, and you should hear a humming/whining noise.
Also, you said it's cranking, but is it cranking normally, or slower than usual?
Engines need 4 things to run; air, fuel, spark, and compression.
Air, you can almost guarantee it's getting.
Compression, if it was just running a couple days ago, that should be fine.
Fuel, start with the above.
Spark, pull a coil and a plug, place the tip of the plug somewhere close to metal while someone else cranks the engine, and look for spark.
Old Mar 5, 2022 | 07:58 PM
Huskerboy7's Avatar
6th Gear
So I got the car started. It was the ecu fuse but after placing it in the car would not start because it kept blowing fuses. So I know the reason for it not starting is the ecu fuse. What is causing the fuse to keep blowing? The fuel pump works. I am just seeking information on why I keep blowing fuses. I believe the 2 relays are good under the steering wheel on the left hand side. Thank you
Old Mar 5, 2022 | 08:03 PM
Pair of TLs's Avatar
A wire is grounding out?
Old Mar 5, 2022 | 08:08 PM
Huskerboy7's Avatar
6th Gear
Thank you. Which wires should I check first?
Old Mar 5, 2022 | 08:51 PM
You could work backwards from the ECU.
Does a 20A fuse blow?
Old Mar 6, 2022 | 02:31 AM
Synchro's Avatar
Get a wiring diagram for that fuse and start looking at the easiest wire you can get to.
Otherwise, get it towed to a mechanic.
Old Mar 6, 2022 | 06:52 AM
Huskerboy7's Avatar
6th Gear
Does anyone have a wiring diagram they can send me for the ecu f1 wiring
Old Mar 6, 2022 | 09:15 AM
peter6's Avatar
https://acurazine.com/forums/third-g.../#post15344256
Old Mar 9, 2022 | 04:43 PM
Huskerboy7's Avatar
6th Gear
So i have narrowed it down to the crankshaft sensor. I believe when i did the timing belt i didnt put the wires behind the tensioner and they were pinched. The car will not pop a fuse if the connection for the crank sensor is disconnected but once you plug it in it blows the fuse instantly. I am replacing the wires for the crank sensor. Is there a way to test the crank sensor before i buy a new one? i believe it is still good i just need new wire harness.
Also i noticed there was a wire fraying right below the intake maniford. One wire was just red and on the other connection the wire was blue/red. I had no idea what these wires were for. Any help would be great. Thanks
Old Mar 11, 2022 | 12:42 PM
Huskerboy7's Avatar
6th Gear
any ideas?
DOH
Aug 14, 2021 03:51 PM
Punnisher
Jul 21, 2015 10:54 AM
Oh1TypeS
Apr 4, 2008 11:45 AM
nbennettksu
Apr 5, 2007 09:06 PM
ChucksCL-S
Sep 11, 2005 04:16 PM
