2004 TL cel problem-please help-codes P0171 and P0174
Old Apr 21, 2009 | 12:28 AM
2004tl6spd's Avatar
hey everyone i have a 2004 acura tl it has 104,700 miles on it and recently the check engine light came on i had it scanned and it came up as p0171 and p0174 the dealer could not figure out what is was soo they cleared it,and it came on the next day as the same 2 codes then after a day or soo of driving it went off then today it was on when i turned it on and then a few hours later i turned it on and it was off. what can this be??? the cel never blinks its just solid yellow the dealer said maybe fuel injectors but its off now if it was something major wouldn't it be on all the time please help me if anyone knows what this can be again please help me
Old Apr 21, 2009 | 01:32 AM
2004tl6spd's Avatar
no one has any answers for me the dealer is telling me it could be fuel injectors,or bad gas but i always runs 93 premium again any info would be very helpfull thanks again
Old Apr 21, 2009 | 06:44 AM
1fsthatch's Avatar
everyone throws that code it means your engine is running lean p0171 Leand conditon bank 1
p0174 lean condition bank 2
Old Apr 21, 2009 | 09:18 AM
1fsthatch's Avatar
well not everybody but i've seen it A LOT
Old Apr 21, 2009 | 09:56 AM
Majofo's Avatar
Make sure your air intake filter is clean. Then check the intake manifold for vacuum leaks. Clean your EGR valve and run a fuel system / fuel injector cleaner (Seafoam / Berryman's B-12 / Techroline) through the tank (don't get any of this stuff on your paint btw..).
You're also at the 105k mark.. You need new plugs / timing belt / water pump / t/b auto tensioner.. Make sure you adjust / replace your PCV valve as well when doing the plugs. I suggest NGK Iridiums.
you might also want to check the throttle body for leaks or buildup.. they can get dirty and restrict the butterfly valve so I hear (never encountered personally).
Old Apr 21, 2009 | 12:17 PM
2004tl6spd's Avatar
it is up for the 105k service im taking it to the acura dealer when it hits 105,000 they are only charging me $1088.00 for the plugs,t-belt,water pump,coolant flush,check and adjust valves,all new drive belts
Old Apr 21, 2009 | 12:18 PM
2004tl6spd's Avatar
i might have them do a fuel system cleaner as well but they want $199.99 soo im debating...
Old Apr 21, 2009 | 12:24 PM
Majofo's Avatar
wtf!?!
$1100!!!
+$200 for fuel system cleaner???
You're getting kicked in the balls. Plugs are like $60.. it would take you maybe an hour to do them. Adjust PCV valve.. no brainer. I think a fair shop price for timing belt / water pump service is $600.. shop around, some places will do it for $400 incl parts... Go get a can of seafoam or berrymans b-12 fuel system cleaner for $7.. and get your TL out of there asap before they offer to replace your brake pads, cabin filter, & top end clean.
Old Mar 7, 2016 | 12:40 PM
mike1185's Avatar
I'm getting code p0174 but it only comes on of I let the car run for like a half hour if I drive the car and don't let it sit and idle it don't come on I just replaced both cats cause they were bad and all 4 02 sensors were done about 2-3 years ago what do you guys think my problem is please message me I'm new to here and won't be sure to find your response lol
mike1185's Avatar
Please help I'm a mechanic well learning and I do a lot of work to this car myself so any input in what the problem can be would be great the 105,000 mile maintanaice done I have a Injin cold air intake oem only a year old denso coil packs and sparks plugs like I really take good care of this car Also I've done the tranny pressure switches and filter and the fluid is so clean you can cook with it I have used alit of gas treatment in the past which I no now is bad I used to use the black bottle of stp fuel injector treatment so I'm thinking maybe my 02 sensors went bad it's saying bank 2 running lean unless it's my fuel injectors so what do you guys think???
Old Mar 8, 2016 | 12:22 AM
csmeance's Avatar
check fuel pressure to the rear bank of cylinders vs the front bank would be where I'd start.
Old May 15, 2016 | 11:18 AM
mike1185's Avatar
Can a map sensor cause this I ordered a new one anyway and going to replace it
Old May 15, 2016 | 10:29 PM
csmeance's Avatar
it wouldn't cause it to only the rear cylinders as the MAP is for all the cylinders. Have you tried a valve adjustment to see if it helps?
Old May 16, 2016 | 10:45 AM
mike1185's Avatar
No I haven't how much would a shop charge to do that that's the only thing I haven't done everything else is done I put the new map sensor in today I haven't let the car idle for a half hour yet I going to do that and see if the light comes on thanks for your help I heard that the map sensor sends signals to the ecu for the air and gas correct mix ratio
Old May 16, 2016 | 11:28 PM
csmeance's Avatar
yes map sends signals for all the cylinders so it'd make no sense if it was just the rear bank.
You may have a clogged cat on the rear bank as well. Valve adjustment is 2-3 hours of labor depending on how many the tech has done. You'll need to valve cover gaskets too which are around $20-30.
Old May 25, 2016 | 09:06 PM
CubanLynx84's Avatar
under renovations....
I had/have this problem since the day I bought the car, well within the first year of owning it it started. Acura did "updates" changed the ecu and so... even adjusted the valves and had put in a new timing belt way early. My car only has 80k on it. My own mechanic fixed the issue and it was the wiring to the O2 sensor. It just recently started doing it again. I clear the code because it annoys me but there never is a difference if the feel of the performance of the car.
Old Jun 23, 2016 | 06:56 PM
cruisingnycfl's Avatar
I've had this problem b4 too. How is it possible to get bad gas when we're pumping 93 premium??? Could it be that everybody pumps regular and our premium gasoline just sits there?? I'll understand if our cars recommend 87 octane and get those "bad gas" cel...
Old Mar 9, 2019 | 02:54 PM
dea7hr0w's Avatar
bump sorry to bring this back up, but was there an ACTUAL solution ?
Old Mar 9, 2019 | 10:23 PM
AMTMJ's Avatar
LinkDeny
Drudis
Mar 21, 2016 12:44 PM
