2004 TL Aspec caliper bolt threads gone
Old Jan 29, 2017 | 01:22 PM
Jacob Hogan's Avatar
I was putting front brakes on my tl with the brembo aluminum calipers. While going back together, i realised corrosion had destroyed the threads that hold the caliper to the knucle. I called acura and the cheapest i can get a caliper is $430. I want to fix the one i have. Is a heli coil the best way to go or is there something better to use in aluminum? I think the size i need is 14×1.5 but i want to be sure before i order something online.
Any input appreciated! Thanks.
Old Jan 29, 2017 | 03:14 PM
nfnsquared's Avatar
Unfortunately, it's not a rare occurrence. There are lots of threads on this issue. Time sert is probably preferred in this application:
https://acurazine.com/forums/3g-tl-p.../#post15923116
https://www.amazon.com/TIME-SERT-Met...iglink20955-20
Old Jan 30, 2017 | 10:00 AM
01acls's Avatar
Anti-seize will help against the corrosion. The corrosion is actually an adverse reaction between the two different materials of steel and aluminum, know as Valcanic corrosion. The combination of steel, aluminum, and moisture will speed up Valcanic corrosion. The anti-seize will work as a barrier between the two different materials to minimize Valcanic corrosion.
If the holes are large enough you might consider drilling and retapping the threads to the next larger bolt size. If you do be sure to use the same bolt Grade rating or higher. Don't rule out American threads as the next larger bolt size.
Old Jan 30, 2017 | 10:08 AM
Galvanic * corrosion
Old Jan 30, 2017 | 10:13 AM
01acls's Avatar
Thank you that's what I meant.
Old Jan 30, 2017 | 02:09 PM
nfnsquared's Avatar
I wouldn't use a/s. It totally changes the torque spec for the bolt....
Old Jan 30, 2017 | 06:22 PM
srg818's Avatar
I agree. The factory torque is already 125 foot-pounds, I can't imagine torquing that much with A/S However, I remember seeing a post on here where someone torqued the caliper bolts(dry, no A/S) to something a little less than 125 ft/lbs for fear of stripping the threads and he found that they started to get loose after some time, so I would recommend sticking to the factory spec for safety's sake.
Old Jan 30, 2017 | 07:28 PM
01acls's Avatar
Yeah that's a tough call because at $450 a caliper and I'm pulling the aluminum off of the caliper when servicing my brakes? I sure would not just keep doing the same thing. But that's just me.
A/S is certainly not for everyone but I would experiment on my own car and maybe take 10-20% off of the torque specs and see how tight that is in relation to a dry torqued bolt by marking the bolt to the caliper for reference. And if it's at or a little beyond AND it took just as much effort to torque the bolts then I would call it good. However, I would be monitoring those bolts very closely for any signs of loosening. Say everything 5k at tire rotation.
Honestly, if you're not comfortable with using A/S on the bolts then don't do it. For example, I wouldn't be comfortable with installing a tread cert but that's just me. I would rather use A/S or buy another caliper than installing thread certs on a brake caliper.
Old Jan 31, 2017 | 11:48 AM
BreezyTL's Avatar
Alum Threads < Steel Threads
Put a timesert in it and never have to worry again, you can also you A/S (anti-seize?) in the timesert as well! When I get around to having to do front brakes, I will be putting timeserts in to avoid this issue.
Old Jan 31, 2017 | 05:06 PM
srg818's Avatar
Time-Sert or threaded steel sleeves really should be a factory default from Brembo, I don't know why they don't...unless it's for a way to maintain revenue.
srg818
3G TL Photograph Gallery
21
Dec 10, 2016 09:00 PM
DopeBacon
Oct 24, 2016 06:37 PM
maharajamd
Oct 20, 2016 04:10 PM
Anicra
4G TL Problems & Fixes
Oct 6, 2016 01:44 PM
