2004 Acura TL Rear-View Mirror Problem
Old Jun 30, 2011 | 04:52 AM
Hawaii808's Avatar
Hello everyone,
I recently bought a 2004 Acura TL and I have encountered what seems to be a known problem with the inside rear-view mirror. There is a oval liquid bubble inside the mirror. I am looking to replace it but I can't for the love of me figure out how to take the mirror off. I have searched the forums and have only run into instructions for removing a 2nd gen rear-view mirror. Can anyone explain to me how to remove it or link me to something that can show me? Thank you for your time.
Hawaii808
Old Jun 30, 2011 | 08:50 AM
guitarplayer16's Avatar
That bubble is the dimming chemical.
I'd get that fixed as soon as possible before it could even explode all over your car interior.
Did you talk to the dealer about it?
The removal of the mirror is very similar to the 2G TL.
Old Jun 30, 2011 | 04:32 PM
Hawaii808's Avatar
Thank you Guitar. I'll change it out ASAP. I heard the chemical eats plastic, yikes!
Old Jun 30, 2011 | 09:15 PM
Hey man, no problem =)
The chemicals are also a health hazard supposedly too!
Old May 10, 2014 | 12:47 PM
jimmriley's Avatar
Jmr
Trim removal to access rear viewmirror instructions 3g tl
Thanks, the diagram was a big help...I found the instructions to remove the trim etc to get to the mirror in a video for a 3rd gen TL . Similar to 2gen but some differences. I suggest anyone trying this look at the diagram above and review the video below. Its a quick job once you figure it out. I am cautious/slow because I dont want to break anything the first time I do something like this.
This video talks you through it. He doesn't actually show the removal. Basically pop off the dome light covers by prying at the back(toward rear bumper) of the cover. I had to mess up the reflector a bit to get the reflector out. Only need to remove one of the dome covers. I popped off the right(passenger side) dome cover. I then removed the reflector part, then pulled the entire black portion of the plastic down(the two lights etc) as per the video guidance. Then remove the 4 x8mm bolts, pull the outer ring of plastic down and unplug the mirror plug. I left the rest of the plugs attached and let the plastic trim hang down. I had good access to the bolts etc. gently rock the mirror left and right and push the mirror forward parallel to the floor. I didnt need to use a rubber mallet. I think it would be safer to use a rubber mallet so you dont break anything in the base. Reinstall was reversal of disassembly. Good luck
AndrewS
19
Mar 14, 2024 06:59 PM
chrisr
Dec 4, 2015 02:17 AM
handsom-hustla
Nov 13, 2015 05:04 PM
Rocktman1
Oct 31, 2015 02:33 PM
Redsand353
Sep 6, 2015 01:03 PM
