'07 Acura TL Type S problem
Old May 9, 2014 | 12:45 PM
dill07types's Avatar
7th Gear
Hey guys am new to this site, I have a 07 Acura Tl types. Today when i was driving the car shut down at a stop sign, it was stuck on st gear, the brake was locked, and the clutch was stuck. Did anybody ever had this problem, or knows about? BTW it started working after like minutes.
Old May 9, 2014 | 12:46 PM
7th Gear
* 1st gear
Old May 9, 2014 | 12:52 PM
so, you do have a 6 speed manual transmission?
Old May 9, 2014 | 01:05 PM
7th Gear
yea
Old May 9, 2014 | 01:12 PM
when you say "shuts down"
does that mean the engine is off?
Old May 9, 2014 | 01:15 PM
7th Gear
yea it turned off with gear stuck in 1st gear and the clutch was stuck
Old May 9, 2014 | 01:17 PM
bp_spets's Avatar
stuck as in you couldn't push the pedal down?
Sounds like something happened internally in the clutch. either the throwout bearing blew up or a clutch disk spring escaped and got jammed somewhere.
Old May 9, 2014 | 01:50 PM
7th Gear
yea the pedal was stuck like half way.
Old May 9, 2014 | 01:54 PM
7th Gear
you can push the pedal down but it won't go back up.
Old May 10, 2014 | 08:44 AM
wessyk87's Avatar
Sounds like a bad clutch master or slave cylinder, check your clutch fluid reservoir level. Sounds like you lost hydraulic pressure allowing the clutch to fully engage stalling the car.
Old May 11, 2014 | 08:07 AM
7th Gear
Yea the slave cylinder was the problem.
handsom-hustla
Nov 13, 2015 05:04 PM
Allen_442
Sep 8, 2015 06:01 PM
Glorygang600
Sep 5, 2015 01:17 AM
voigt
Sep 2, 2015 10:44 PM
