08 Base Driver side mirror issue
Old Oct 12, 2019 | 08:44 PM
frankjnjr's Avatar
The driver's side view mirror, on my 08 Base model operates horizontally, but not vertically. I replaced the actuator with a new OEM part, and swapped the control switch with a known good switch. I adjusted the vertical position manually, to make sure the mirror was positioned properly. The right side view mirror operates as it should. After a thorough review of side view mirror issue posts, I haven't found anyone who has experienced this problem before. Any suggestions?
Old Oct 25, 2019 | 02:06 PM
LoveMyTL-S's Avatar
Anyone?
Old Oct 31, 2019 | 01:47 PM
cammark35's Avatar
new actuator, good switch but only partial function... suggests a loose, broken wire or poor connection somewhere. remove the actuator from the housing and apply voltage directly to the pins. (doesn't need to be fancy... a 9V battery and two paper clips would work) if both work in both directions work back towards the switch until it fails to move. now you know where to make your wire repair.
Old Oct 31, 2019 | 03:06 PM
csmeance's Avatar
The wires that run from behind the actuator pass through a small hole behind the mirror mount. It's very possible that the wires have frayed/loosened from a connector.
Old Oct 31, 2019 | 05:04 PM
frankjnjr's Avatar
thank you both, very good suggestions. will check tomorrow if and when it stops raining. thanks again
Old Nov 3, 2019 | 04:55 AM
frankjnjr's Avatar
Sure enough, the end (pink) wire was slightly pulled from the connector. Now EVERYTHING on my car works exactly the way it's supposed to. Tx. again for the suggestions.
RicN
Oct 29, 2018 03:32 PM
Bcustons
Dec 17, 2009 08:17 PM
RDXControl
1G RDX Problems & Fixes
Mar 13, 2008 09:47 AM
