Rear view mirror rattling?
Old Apr 3, 2018 | 10:34 PM
RicN's Avatar
My rear view mirror rattles like crazy on rough roads. Today I happened to come across a youtube video and the owner of the TL in the video also said his mirror rattled a lot. Is it normal and a new mirror will fix or is there a way to fix the current mirror from rattling? I find it odd since I have never had a mirror rattles like this. Any idea guys? Thanks.
Old Apr 4, 2018 | 06:51 AM
*.jpg's Avatar
Fluvial Geomorphologist
I had it happen to me once and I just jammed it tighter back onto the thingamajig that it's connected to. It's stayed ever since.
Old Apr 4, 2018 | 09:23 AM
dgoodsy's Avatar
Mine does the same, I haven't fixed it yet. It is uncommon enough that it doesn't bother me terribly but I will hopefully be able to get to it before too long.
Old Apr 4, 2018 | 09:31 AM
Glue holds the base to the windshield and the mirror slips on to the base via grooves. pretty much the same way in all cars.
make sure base is properly secured to windshield..then, make sure mirror is attached to base securely by making sure it's in the proper grooves.
Old Apr 4, 2018 | 10:32 AM
truonghthe's Avatar
check to see if your spring clip hold on to the base metal tab, its happened to me when I replace the HFL so I use a flat head screw driver and bent the metal clip back and no more rocking rear view mirror.
Old Apr 4, 2018 | 03:08 PM
MikeTC's Avatar
To add to this, if bending the metal clip did not work, then replace it; it's only about $4 and an easy fix.
Old Apr 4, 2018 | 05:09 PM
EE4Life's Avatar
Forum Contributor
See TSB 06-012 - Inside Rearview Mirror Is Loose.
http://techinfo.honda.com/rjanisis/pubs/SB/B06-012.pdf
Old Apr 5, 2018 | 09:10 AM
dgoodsy's Avatar
awesome information, thanks guys!
Old Apr 6, 2018 | 11:40 PM
Waffeey's Avatar
I tightened the T-20 torx screw after sliding the mirror forwards and off. That's all mine needed. Was nice to not have to jam the mirror tight every 5 minutes like before!
Old Apr 8, 2018 | 07:18 PM
Pair of TLs's Avatar
My mirror pulled right out--the screw was MIA.
Old Oct 29, 2018 | 03:32 PM
StealthTL-S's Avatar
08 TL type-S
I did the same with the torx screw (after I found a t-20 torx screw) after my mirror fell completely off! It's tight now, and back in shape.
noclue02
Jul 16, 2016 12:38 PM
jdm_94-07TypeS
Feb 3, 2012 12:07 PM
vp911
220
May 24, 2006 11:46 PM
Alegend5
Feb 14, 2003 03:01 PM
morpheus6d9
Nov 2, 2001 12:11 AM
