07 Type S-Engine cuts out high rpm
Hi guys. It has happened before but now almost every day when I reach higher rpm about when Vtec is actuated, my car cuts out and feels like a rev limiter, very violently. I have searched this problem but it looks like its more common in honda 4 cylinder engines. I have no engine codes so far and I checked with my scanner. I do not know when my valves were adjusted so I will do that very soon. It is not low on oil and it isn't due but Im probably going to do that also. This is a manual car so it is not the transmission. Any help is appreciated and my apologies if I skipped over any previous threads but I could not find any like mine. Thanks
just confirming it is indeed the vtec cutoff and not the 7200 fuel cutoff.
Have you researched the APP sensor? Accelerator Pedal Position..a bad APP can put the car in limp mode, preventing you from accelerating past 5000 RPM
I believe some have had good luck changing out the APP, while some say it didnt make a difference...
anyway; we've got you closer to the suspected parts...either the vtec solenoid or the APP sensor
So Ive realized that if I gently roll into the throttle it will not cut out but if I stab the throttle from a stop it will break up about 5k. Also on the way to work it threw a CEL so I will scan it after work and see what it says.
I didn't think so either. I know there is an issue with one of the cats because the car smells pretty bad when driving harder. I really need to adjust valves and replace all the plugs, Id replace the plugs before but the seals are bad so I wanted to do all the gaskets at once when I tear it apart for the adjustment. Ill see if theres a way to test the MAP sensor.
So I feel really dumb because Ive been wrenching and modding cars for a while but last time I checked my oil it was within the lines, I checked yesterday and had to add almost 2 quarts of oil. Now it goes to redline no issues and runs fine. I go to Honda for oil changes because nowadays its just so inexpensive, plus they use oem filter. I always check level after I go. Its been about 4,400 miles since last oil change. 2 quarts of consumption is not horrible for a high mileage car but was wondering your guys' thoughts. Anyways Im doing the valve adjustment in the next week or two and Im also going to change the pcv valve and spark plugs. Thanks
Maybe the low oil level caused some sort of issue with the VTEC solenoid at high RPM's. That's odd that it would throw a misfire code though.
2 qt's of oil in 4,400 miles isn't ideal, but I wouldn't sweat it too much either. I might have missed it, but how many miles do you have?
Yeah I think theres still something else going on also. It has 183k miles, TB and WP service done about 160k miles. I asked last owner about spark plugs and he did not know if/when they were changed. When I checked a couple they were full of oil from the valve cover/spark plug well gaskets being rock hard. All of this will be replaced soon.
My '07 TL Type-S 6spd just started doing the same thing today! I have not yet done anything to diagnosis the issue, but this thread has been helpful as a place to start. 90foxnotch, did you resolve the issue???
It's not that it's low oil pressure it's low oil volume. Even a temporary loss of oil pressure, or low pressure, would trigger a flashing oil indicator on the dash. The reduced rev limit is caused by a lack of oil volume since the VTEC System is actuated with oil acting as a hydraulic fluid. If there is not enough extra fluid to activate the VTEC System the ECU triggers the reduced rev limit.
Vtec works base one engine oil pressure and with modern car the PCM got involved as well, its common for you not experience that since ford doesn't use any variable valve timing until mid to late 2000s (its doesn't call Vtec but its similar concept)
That's pretty cool stuff. Ive got a few things to learn about on my coyote. It will be the most advanced engine Ive had in the notch
yeah the Coyote has variable valve timing and adjustable cam shaft on intake and exhaust, A lot of Mustang fan making fun of Honda Vtec but they fail to realize Ford utilize the same technology.
The 2018-2019 GT 5.0 motor actually use the same technology found in Lexus ISF (07 IS350, GS350, GS460 and LS460 using the same concept) where it feature 16 injectors total (8 for direct injection and the other 8 for port injection) depend on engine load and speed it can switch between DI or Port injection, lead to better fuel economy and solve the issue of carbon deposit on the back valve in DI car.
Ford is the ONLY domestic company adapt foreign technology and so far they doing pretty good. DOHC and dual injectors tech explain why Coyote motor out perform LS series (HP/ litter) every time.
Yeah man the VVT is pretty cool stuff, the direct injection Im not very familiar with but I know tuners are a lot more comfortable with it now than when cars started coming out with it like the mazdaspeed3's. Yes Id say Ford is doing awesome but then I also heard terrible things like the new gt500 not being offered with a manual. Shelby would be furious haha Along with the great fuel injection they are now making the new engines capable of a safe and somewhat reliable 900hp. The new 10 speed is also a great addition
jwoods4290
Jun 14, 2018 02:08 PM
