'07 TLS check engine light flashing
Old Feb 26, 2011 | 10:53 PM
tworkin05's Avatar
I was driving my car I hit the gas and the traction controlling came on as normal but then I noticed the check engine light flashing for maybe 20 to 30 seconds and then it stopped I only punched it to sixty and I just got my car back from the dealer last week look at my other post for what was wrong is this bad?
Old Feb 26, 2011 | 11:01 PM
Bearcat94's Avatar
AZ Community Team
Happened to me once. I was driving it hard (track day) and just starting a new session the CEL flashed a few times, then went out.
It's never come back on since. I figure I might've gotten a couple of mis-fires or some fleeting issue.
If it doesn't happen again and/or the CEL doesn't stay on, I wouldn't worry about it. Any messages in your Nav screen?
Old Feb 26, 2011 | 11:13 PM
tworkin05's Avatar
No messages on nav screen. Its driving like normal
Old May 24, 2011 | 11:48 PM
Johnny_b's Avatar
On a trip to RI last week my CEL started flashing intermittently well into the trip while on the highway. Now it does it whenever I take it on the highway at speed and the car is well warmed up. Then tonight right after I pulled off the highway, the idle started going nuts bouncing around, while the CEL was still going on and off. Felt like it wanted to stall but didn't. That's the first time the idle thing happened and didn't happen after that. There are no noticable changes in performance. Anyone know what the problem is?
Old May 31, 2011 | 04:59 PM
05AV6's Avatar
car is misfiring, usually if its on more than one cylinder its the crank position sensor causing the issues.
Old May 31, 2011 | 06:31 PM
EATSLEEPRACE's Avatar
6SPEED FEVER
^^what he said^^^^better hope its a sensor
engine is misfiring thats not good, usually means ure having to much fun with it.
Old May 31, 2011 | 06:58 PM
csmeance's Avatar
a blinking check engine light means that the car is having misfires at the moment. It could be caused by a variety of things such as improper fuel mixture, spark, etc.
If it keeps on repeatedly happening, you may want to run a fuel cleaner to clean up the injectors and as well have the fuel lines checked to see if they have the right pressure. As well you may want to check the spark plugs and coils.
Old May 31, 2011 | 09:21 PM
vanhan's Avatar
6th Gear
get the thing scanned... any misfires will set as history codes in the PCM..
MikeYutkin
Sep 10, 2015 10:13 PM
Bahamanurse1
Sep 10, 2015 10:05 PM
HeloDown
Sep 8, 2015 06:51 PM
bryan zaragoza
Sep 8, 2015 12:28 AM
whitesoxsfan12
Sep 7, 2015 04:07 PM
