'07 TL-S lots of problem!!! Need help
Old Nov 15, 2011 | 05:56 PM
neonmods's Avatar
hi guys ,
1 st of all, one of my friend give me is tl-s for couple days because he is outside for the work..
couple thing i will like to repair before he came back but i need you help
1st thing: No flasher either left or right,even a click . 0 nada nothing , even the high beam not working..everthing on that controller is not working , even fog light.
2nd thing. There is a vibration around 15-20 Mph , you can clearly feel it in both front wheels ,
3rd thing: remote controller not working . there is no battery inside as usual !!!..
4th thing: when i am at wot i feel the car go to right and left , can really stay straight ... and before you ask i already drive 500whp fwd car so no it's not because it have power....
now i am waiting for you advised guys
thanks
Old Nov 15, 2011 | 08:43 PM
Elegant TYPE S's Avatar
Being an Acha Bacha in
In order:
1. Check the turnsignal/flasher relay and fuse associated with it first
2. Vibration issues at that speed are most likely associated with either bad axles or poor balancing. Elaborate on where you feel the vibrations.. in the steering wheel or on the floor?
3. I'm sure you can handle that one.
4. That is torque steer and normal for all TL's.
Old Nov 16, 2011 | 04:53 AM
neonmods's Avatar
Originally Posted by Elegant TYPE S
In order:
Number 1 : i will check again my self, but my friend told me the relay and fuse was ok .
number 2 is both , steering and floor
but i put more air in the tire and it's seem to be ok now.
Number 3 yep i will go to the dealer
number 4 is now resolve: one tire was low..
Old Nov 16, 2011 | 09:27 AM
lsimmons's Avatar
#3.... Dont go to the dealer. Just an autoparts store or walmart or walgreens will carry the battery for the remote. It's easy to put in, just a small screw driver to open it up. And it will be cheaper!
mada51589
Jan 9, 2025 04:40 PM
cycdaniel
Dec 17, 2019 10:58 AM
MistaWet
Sep 15, 2015 08:26 PM
brandnewcolony
Sep 12, 2015 10:39 AM
jordanboi
Sep 5, 2015 01:33 AM
