07 TL/S 71500 miles
Old Jul 25, 2010 | 08:09 PM
rwatson908's Avatar
Unhappy 07 TL/S 71500 miles
problems came quick!
I need the 65000 miles service. Recently my AC, usually set on auto began fading out and stopped working. I could hear the fan blowing but no air. Started working after I would stop and turn off engine for about 5 minutes. This weekend while OOT, the engine started switch light came on, the Savannah service said, no problem, drive home and get serviced. Enroute home the thermostat went from mid point to below C, to H. Engine light came on. I stopped and set for about 10 minutes and all was fine. Then the transmission light message appeared, the D indictor began to flash. The VSA message came on, the gas filler light came on.
I continued driving home, Sunday on I-16 is no place to get stuck. Prayers and crossed fingers we made it. No AC again.
Besides being over my service time, any ideas. I have a feeling $$$$ will be the issue. I have 29000 remaining on warranty. Help!
Old Jul 25, 2010 | 10:54 PM
YeuEmMaiMai's Avatar
if you have warranty left not a problem unless you totally abused the car........
Old Jul 25, 2010 | 11:06 PM
1islandparadise's Avatar
Sounds like you got alot of problems bro. The bumper to bumper will only take care of it up to 62K if its CPO (50K factory) and 100K for drivetrain. Sounds like you got a mix of both problems. You should "try" the dealership and just pay for the diagnostic fee, if you even have to saying that the warranty will cover it.
Old Jul 27, 2010 | 01:17 PM
rwatson908's Avatar
Acura dealer update. The PCM is bad, warranty replacement. The service called and told me 17 error messages. 60+ service is 483.00, I need brakes and rotors turned, 435.00. I live in north Atlanta. Does anyone know where I can get the brakes down cheaper and maintain the same quality? Thanks, RW
Old Jul 31, 2010 | 03:04 PM
VQPower37's Avatar
buy your own brakes and do it yourself with diys on this forum, its pretty ez with some simple tools
Old Jul 31, 2010 | 06:35 PM
skd2k1's Avatar
I use rotora ceramics for the brembos. Bought them here:
http://store.excelerateperformance.c...c/g-51735.aspx
Old Aug 14, 2010 | 10:44 AM
rwatson908's Avatar
Thanks for the replies. I just bought EBC red pads. They were listed and confirmed by sales to fit my 07 TL/S. I just can't spend 206.00 for the Acura Brembo pads. I looked for someone who sold the Brembo, Goggle not helpful!!
Old Aug 15, 2010 | 02:42 PM
VQPower37's Avatar
brembo pads can be had for 150 on ebay from some dealers
Old Aug 15, 2010 | 06:34 PM
csmeance's Avatar
a lot of members like the Duralast CMAX gold pads which are relatively cheap and quiet! As far as the 60K service goes, don't pay 435 dollar!
Can you operate a screwdriver without hurting yourself? If yes, then you can do most of it yourself and save some $$$. You can buy the engine and cabin filters for 30 dollars and change them yourself. 4 screws for the engine air filter and a few clips and screws for the cabin one. Then there's the transmission fluid change that needs to be done, a DIY is posted here with pictures to make it easy! As well, you will need to do a brake fluid flush which isn't that hard either, DIY's are posted as well.
Add to that a tire rotation/new tires and as well your brakes and of course and oil change and you'll be set!
Old Aug 16, 2010 | 06:11 AM
Indy04TL's Avatar
Go to www.tirerack.com and check out their products and prices. They are a sponsor of this forum.
Old Aug 17, 2010 | 12:54 AM
gotkilled's Avatar
NBP is a pain...
+1 on the CMAX pads. They're great
Old Aug 17, 2010 | 01:37 AM
TLS4TL's Avatar
I got mine at Rotor Pros in SoCal. Ask for Rich, tell him Tom L. sent you.
Old Aug 17, 2010 | 01:50 PM
Majofo's Avatar
OP, was moisture the culprit in your pcm failure? If so, you're lucky more permanent damage didn't occur.
I'm on dg ceramics myself on both the X and TL, they're great. I'm pushing 30k miles on both.. still good. When I'm done with them, I'll take them in and get a new set free.
mada51589
Jan 9, 2025 04:40 PM
o8 ENVII 8o
Nov 30, 2015 04:23 PM
Legend2TL
Nov 20, 2015 07:31 PM
mugen_kid
Nov 13, 2015 10:38 PM
01CLOwner
Oct 9, 2015 01:07 PM
