Hi there,
Just joined the community. Im having some issues with my TL and I've tried to fix a little but cannot find whats wrong.
Issue: When I start my car my automatic is stuck in Park, I have to upon the little cover next to the shifter and press the manual release to unlock every time I shift out of park or shift from drive to neutral (gets stuck in neutral) to go to park.
Some Checks Ive done from message boards Ive read:
- Tail lights work as required.
- I don't hear any light "clicking" when I start the car or when i press down on the brake.
- Sometimes in really warm, I don't need to press the manual release.
- I did spill a soda (although I dont think alot) prior to this issue happening.
What Ive done-
I've tried to open the console to get to my shifter and put some distilled water on it. It helped for a few days but the problem came back. By helping it worked most of the times but after a few days it stopped working and I needed to go back to pressing the manual release.
Can you guys tell me what I can do right now. Am I stuck with just taking it to a dealership and getting it checked there?
Thanks!
What Ive done-
Thanks!
JJH
close
- Join DateJan 2012
- Age35
iTrader Positive Feedback100
iTrader Feedback Score(1)
Liked:352 Times in 254 Posts
Check your #32 accessory fuse and the other 7.5 fuses below it. One of them controls your shifter lock. I've blown mine before and had the same issue you're having.
Check fuse #13 by the way are you SURE you're brake lights are working? Id check that over if i was you because the brake lights not working cause the security mechanism on the shifter to engange so u cant shift out of park without manually unlocking it.
