'07 TL braking problem
Old Feb 15, 2011 | 01:47 PM
tmotors's Avatar
I am having a hard time figuring out a soft brake pedal issue. I have already replaced the master cylinder with an OEM part. I have bled the brakes two seperate times. After bleeding the system the brakes have plenty of pressure for a month or so. Then the pedal gets soft again. The master cylinder is full each time, yet I can get some air out of the lines. There are no signs of leaks around the brake calipers or the lines.
Old Feb 15, 2011 | 02:02 PM
in the master cylinder, is there a rubber seal?
Old Feb 15, 2011 | 02:13 PM
Bearcat94's Avatar
AZ Community Team
http://techinfo.honda.com/Rjanisis/pubs/SB/B07-041.PDF
You may need to follow the instructions on this page if the direct link doesn't work. https://acurazine.com/forums/3g-tl-2004-2008-93/3g-tl-technical-service-bulletins-tsbs-3g-garage-j-016-a-613659/
This is for TSB 07-041.
Old Feb 15, 2011 | 02:32 PM
You may need to follow the instructions on this page if the direct link doesn't work. https://acurazine.com/forums/showthread.php?t=613659
thanks bearcat, didnt know this.
was working on my car one day last week, and I messed with the master cylinder's rubber seal.
As I went to drive a few days later, my brake pedal went to the floor. I knew I had air in the lines.
the rubber seal had become too large, looked like the pressure enlarged it, and it wouldnt sit correctly.
I ordered a new one, should be here any day.
Also, I jacked up the car and took off all the brake lines as I'm anticipating SS lines from excelerate.
At least, I know about the TSB, if my troubles dont stop.
Old Feb 15, 2011 | 03:14 PM
tmotors's Avatar
The seal is fine. I have found out that the VSA modulator has given some of the 05/06 TLs problems by letting air into the system. Who knows?
Old Feb 15, 2011 | 03:18 PM
yes, that is what the TSB stated.
mada51589
Jan 9, 2025 04:40 PM
udelslayer
1G RDX Problems & Fixes
May 6, 2016 12:27 PM
CheeseyPoofs McNut
Oct 11, 2015 11:25 AM
rklatzkin
Sep 23, 2015 04:08 PM
HOWELLiNC
Sep 10, 2015 01:39 PM
