06 Trans leak behind range/gear position switch???
Old Feb 7, 2018 | 08:05 PM
djtsmith007's Avatar
ElectroMechanicalEngineer
Been seeing a couple drops every day and have it narrowed down to (i think) behind the range/gear position switch on the transmission. At first thought it was the 3rd or 4th gear pressure switches but once i got under it today, cleaned it off i think it might be this seal. Only problem i cannot find ANYTHING on replacing this seal.
Has anyone done it? First two images of my car, cleaned up the gunk. 3rd image is taken from a post on here about the actual switch showing the seal
Attached Thumbnails 06 Trans leak behind range/gear position switch???-tl1.jpg   06 Trans leak behind range/gear position switch???-tl2.jpg   06 Trans leak behind range/gear position switch???-tl3.jpg
Old Feb 8, 2018 | 10:32 AM
guitarplayer16's Avatar
I had the same leak. Take off the sensor cover, then the sensor and then you will see the shaft and a seal around it. Replace the seal and it will stop leaking. My old seal was so deteriorated when I removed it.
Im on mobile right now so can't confirm the seal part number.
shtewps
Mar 5, 2021 09:49 AM
spydercatt
Jun 21, 2015 05:26 PM
assclown
Apr 29, 2013 02:53 PM
98BlueStreak
1G CL Problems & Fixes
Feb 12, 2013 03:52 PM
spydercatt
Jan 28, 2013 06:19 PM
