'06 TL brakes are squeaking/squealing need advice!
Alright so i have an 06 TL 6 speed. I recently purchased the car and the previous owner informed me he had just gotten the front brakes replaced. I have the reciept showing the shop replaced the rotors and pads. The pads used are not OEM.
It only squeals when u apply the brake softly once you push on it harder it goes away. Yes i searched the forum already but didnt really come up on a conclusion on how to fix thks issue.
Hoping to see what you guys think i should do.
P.s also mods if this is in the wrong section im apoligize just wasnt sure where to put it. Thanks.
TLtrigirl (04-27-2012)
New pads, new rotors, that shouldn't be the problem.
Take the pads out, regrease them properly. Then rebed them properly. I'm sure you will be fine after that.
And a LOT of brake setups will squeal a bit under light load.
I just want to see what options i have to get rid of the squeal.
Was thinking on switching the pads to duralast cmax pads since i seen alot of members on here vouching for them..
Lifetime warranty...little to no dusting...great price.
However the bite isn't that great. If you don't do any spirited driving then the golds would work just fine.
You need to take the braked apart and grease everything real nice. Be sure to get the back and sides of the pads, and the pins. Before greasing tho, use about a can of brake cleaner on each side to get all the dust and gunk out. I dont worry about bedding brake in unless its a performance application and Ive never had any problems. If that doesnt help, do it all over again except this time turn the rotors and buy better pads.
I can divide by zero
Regrease the pad backing like others have stated. If you still have noise, then I'd try to bed the pad. 90% of the better pads on the market will do away with most, if not just about all common noise issues from doing this alone. If it's still making noise, it's some uber cheap-o pad compound and you might as well just change it out.
Does your car have the stock rotors or do you have slotted or holed rotors?
Reason I ask is I put some slotted rotors on my Wife's Pilot with some Hawk pads and the Pilot had a high pitch noise as described by OP. We switched to OEM pads and the problem went away. I tried the other advice on this thread and nothing worked.
Alright guys so what grease application should i use on the pads??im going to try and see how that works if not ill change out the pads on sunday.
Also rotors were replaced by previous owner and are not drilled or slotted.
I use Mobil 1 grease on the back of my pads, but if you goto any auto parts store, they'll have grease for brake jobs. Also a nice heavy grease that one would use for wheel bearings (if anybody here even knows or remembers the days when you have to service and repack wheel bearings with grease at each brake service) work nicely too, and seems to be a little cheaper at times too.
The anti-squeal stuff they sell at the store is actually a rubber glue that dries. I would not use it as it's a pain to get off later on. The OEM pad set now include a special brembo copper anti-seize paste. To me this says, use a little anti-seize on the backs of the pads and your good. Instead of getting the brembo grease for $40, buy a small $1 packet of silver anti-seize from the parts store, or a whole tube of the copper stuff. Keep in mind the original instructions said to only use Molykote M77 paste, but they switched to the copper Brembo grease after the noise TSB.
BTW: It's only SUPPOSED to go where the pads touch the shims, and where the shims touch the pistons. Not on the pins or the pad spring or the caliper itself.
![](https://farm4.static.flickr.com/3078/5768635475_bfd6b6e42e.jpg)
The anti-squeal stuff they sell at the store is actually a glue. I would not use it. The OEM pads include a special brembo copper anti-seize paste. To me this says, use a little anti-seize on the backs of the pads and your good. Instead of getting the brembo grease for $40, buy a small $1 packet of silver anti-seize from the parts store.
So we regreased the back of the pins and pad already had plenty of grease. Went to bed them in and they stop sqealing for a while, but now its back again. Dont know what it could be..
Thinking about just throwing some better pads in there.
Sorry about not ever coming back to this thread.
I did get the problem resolved. Ended up changing pads to Duramax Golds with lifetime warranty. Greased them up real good and bed them in. Havent had the problem since. Some minor squeaking when the pads are cold but nothing serious.
GWEEDOspeedo
01-15-2016 10:39 PM
soupi
14
11-15-2015 11:15 AM
