06 TL 60K Scheduled Maintenance
Old Jun 29, 2010 | 05:11 AM
johndckim's Avatar
06 TL Aspec
Question 06 TL 60K Scheduled Maintenance
Is it worth doing the 60K scheduled maintenance? I have no issues with my car and it has a little over 56K on it. I know that the timing belt should be replaced after about 90K. I did the 30K scheduled maintenance and I am not sure if that helped any. I just need some feedback to see if that 60k scheduled maintenance is worth doing.
Old Jun 29, 2010 | 03:02 PM
d-j-m's Avatar
60K maintenance includes a transmission fluid replacement. This is something I wouldn't miss especially if you have an AT, but even in a 6MT I wouldn't miss it. My car never missed any maintenance and my transmission still had that "internal failure". So my advice is defiantly have the transmission fluid looked after. There's a good DIY on here for that and it's an easy task that's fairly cheap if done at home.
I'd have the brake fluid replaced if older than 3 years, and a tire rotation. Of course oil if it's that time.
Overall you need to do the maintenance, but not necessarily at an Acura dealership.
Old Jun 29, 2010 | 07:21 PM
ramos1556's Avatar
8th Gear
^ Agree, if is an AT get it done, you will be glad you did in the future.
Old Jun 29, 2010 | 10:45 PM
I hate cars's Avatar
That's like saying you don't change your oil because the engine hasn't failed yet.
Maintenence is not supposed to "help". Maintenence is a proactive way of preventing problems from happening in the first place.
Old Jun 29, 2010 | 11:37 PM
csmeance's Avatar
60K requires engine filter and cabin filter change along with an oil change. A transmission fluid change is mandatory according to the manual, but in my opinion it should be done sooner at around 30K, and then at 60K.
You should also lube all the door/weather stripping with some 303 Aersopace Protectant or you can use the Famous shin-etsu grease that the parts dept sells. This grease is amazing and works wonders! If you do the seals, don't forget the sunroof and the trunk ones! Also check the wear on your tires and adjust the alignment if necessary
08_UA7_Gr33k
Feb 11, 2016 02:17 PM
LeVeL
Oct 18, 2015 04:19 PM
thegipper
Sep 28, 2015 01:01 PM
c1souk
Sep 28, 2015 11:20 AM
