Rattle or NOT?
Old Jun 18, 2010 | 12:51 AM
meowevil's Avatar
Rattle or NOT?
When I let my car sit under the sun for a while "sometimes" it make some rubber (belt??) moving noise. Anyone else experienced it? If so, any fix?
Old Jun 18, 2010 | 12:57 AM
princelybug's Avatar
LIST/RAMEN/WING MAHSTA 짱
Can you give a better description of your problem?
Old Jun 18, 2010 | 01:49 AM
TheChamp531's Avatar
Chapter Leader (San Antonio)
With the car on? or off?
Video/sound clip would help.
Old Jun 18, 2010 | 08:29 AM
dwb993's Avatar
We need a better description of the problem, obviously. But most rubber noises (not engine related) can be cured with Shin-Etsu grease. Check my thread:
https://acurazine.com/forums/3g-tl-problems-fixes-114/why-shin-etsu-shiznit-745587/
Old Jun 19, 2010 | 11:31 AM
meowevil's Avatar
As for today I dont know when will this "rattle" or sound occur again, I will try to record it as it happens again. I let the car sit under direct sun light and then get inside and turn on my engine. Next i heard some "rubber" or plastic scratching sound coming from the front (i am not sure is it inside the steering wheel or from engine, but not from center units)
Old Jun 29, 2010 | 01:59 PM
ChicagoNick's Avatar
ChicagoNick
Yes!!
I have that SAME noise! Same scenario.
After the car has been sitting in the sun, temp is hot, etc.
I start the car and I hear that noise... I just can't remember if it makes the noise before/after I put it into drive.
I can't even pinpoint where it's coming from. It just does it once and sounds like something is rubbing or shifting and then I won't hear it again until it's sat for atleast 4 hours in the sun.
Old Jun 30, 2010 | 01:20 AM
meowevil's Avatar
By any chance did you able to record the sound? It happen kinda random, and I dont have my camera with me all the time. Can you record the sound for both of us if possible?
Old Jun 30, 2010 | 07:07 AM
ChicagoNick
I'll try to record it with my iphone... the mic is really sensitive on it.
It wasn't hot enough yesterday (low 70's) for the noise to happen. But it'll be hotter tomorrow and friday.
its so strange.
marcelft
Jul 10, 2018 06:17 PM
udelslayer
1G RDX Problems & Fixes
May 6, 2016 12:27 PM
CheeseyPoofs McNut
Oct 11, 2015 11:25 AM
jaynatlanta
5G TLX Problems & Fixes
Sep 15, 2015 11:08 AM
3GTLOwns
Sep 9, 2015 09:51 PM
