06 ASM 5AT Navi One Month problem list
Old Jul 10, 2006 | 02:19 AM
athlon03's Avatar
Fix List:
1. alignment: steering wheel off center to the left
2. metallic rattling noise on bumps and acceleration around 2000 rpm from under front passenger floor area
3. rattling noise upon initial acceleration/braking from shifter area. Sounds like maracas
4. driver door panel rattles/buzzes at highway speeds
have not been to the dealer yet, but plan to go soon. any advice on these issues?
Old Jul 11, 2006 | 01:36 AM
SSM06TLwTreo650's Avatar
Originally Posted by athlon03
Fix List:
Hi Athlon,
I just bought my new TL this past week. Everything has been fine on mine except for the alignment. Instead, my steering wheel in the "neutral" position is turned to the right. I would say it's about the 12:30 to 1 o'clock position. For the most part, it does go straight with a slight drift to the right. When I break without holding the steer wheel... the car really goes to the right. The harder the breaking, the more noticeable it is.
The good news is... I called my dealership and they do not have any problems with me taking it back in to check and fix the alignment problem.
I wonder if this is common or anything to worry about. I'm sure not all of them come perfect. Sometimes one slips through and all that is required is just an adjustment, not that it is damaged or anything is "broken" per se.
Good luck with your new TL.
Old Jul 11, 2006 | 01:49 AM
DustFreeVinyl's Avatar
Brake dust is a badge
Seems like a lot of people have experienced the alignment issue, myself included. It took two trips to the dealer to finally get it fixed but now it's straight and tracks dead on. I haven't had any rattling issues though besides the subwoofer when the volume is cranked up.
Old Jul 11, 2006 | 02:52 AM
Flight24's Avatar
You know what? My alignment is little off to. It kinda goes off to the right. I will give my dealer a call tomorrow.
Old Jul 11, 2006 | 06:10 AM
athlon03's Avatar
yeah that's what i meant, i have to keep the wheel to the left to prevent right drift
Old Jul 11, 2006 | 06:22 AM
egorss78's Avatar
Fix List:
issues?
Had the same issue wth my 04. Ended up need to change my cabin air filter so I took the glove box area apart anyways. Ended up bieng a medal bracket that connected the glove box latch to the dash. A screw had fallen out, and the 2 peices were rubbing.
Hope that helps.
Old Jul 11, 2006 | 06:45 AM
Drunkenmunky23's Avatar
TLove
Originally Posted by SSM06TLwTreo650
Hi Athlon,
I just got my TL last week and my sister got one two, and we both have this problem, just as described by SSM06TLwTreo650
i gotta give the dealership a call.
Old Jul 11, 2006 | 07:19 AM
pimpin-tl's Avatar
I also have this problem and plan to get it fixed at the first maintenance.
Old Jul 11, 2006 | 10:33 AM
Carl Spackler's Avatar
#2 is the heat shield. They will replace it.
Old Jul 11, 2006 | 11:58 AM
Xpditor's Avatar
Check your car in a flat parking lot. Then check air pressure in the tires.
Most complaints from poeple about any car, is a slight drift to the right (or, in England- to the left).
Streets and highways are not flat. They are crowned so that water will flow towards the edge and does not pool.
That means that the natural path of the car would be slightly downhill and it takes a slight pressure to the left to go straight. By slight, I would say no more than an inch or two at the outer circumference of the wheel.
But it never hurts to have the dealer check it.
There are heat shields under cars and they are notorious for sometimes buzzing. That is also easily fixed.
I had a buzz in my driver's door that turned out to be DVD-A cases I had put in there.
Old Jul 11, 2006 | 11:18 PM
Regarding the alignment: There are a few really long and flat streets close to where I live. The streets run both east-west and north-south. I made sure that I checked the steering by going both directions. Xpditor is right, you should always check by driving on a flat surface because of the way the road crowns and take that into consideration.
What is most evident is the braking test. If your alignment is true (straight), you should be able to apply the brakes at different levels of pressure (low to moderate to high) and slow to a stop in a relatively straight line. It becomes most obvious when the car drifts to one side of the other, that you know that there could be something wrong with the alignment. Of course, this works if your brake pads aren't messed up either LOL. But I'm sure you get the idea.
Oh well, I'm scheduled to be in the shop this weekend to have my alignment checked I can't wait until this is finished and I can finally drive the car.
Good luck to everyone that is taking their cars in for alignment issues. Please post with your results!
Old Jul 12, 2006 | 09:13 AM
DMZ's Avatar
DMZ
Head a da Family
I had a buzz on last night while watching the All Star game
Old Jul 12, 2006 | 01:26 PM
brianp6621's Avatar
Going both directions (in the correct lanes) on the same road will not eliminate the road crowning as the source of pull. The crown is in the center of the road (where the center yellow lines are painted) and will slope down to both sides. So if you drive northbound and then southbound you are still experiencing a slope to you right. You need to drive both directions on the exact same piece of pavement/concrete to determine if the pull is the tilt or the alignment.
Also the stopping test (as you somewhat mentioned) is also very sensitive to the condition of your brake pads and rotors and other factors in you brake system.
Old Jul 17, 2006 | 01:19 AM
athlon03's Avatar
alright folks, heading out to the dealer first thing 8am tomorrow. hope everything works out and they give me a loaner car.
Old Jul 18, 2006 | 09:53 AM
CobraGuy's Avatar
Most good alignment techs will compensate for the crown in the road.
TLDude876
Dec 28, 2016 03:18 PM
handsom-hustla
Nov 13, 2015 05:04 PM
lovic87
Sep 9, 2015 10:18 AM
asahrts
Sep 4, 2015 05:55 PM
SUPRMN84
Sep 2, 2015 11:50 PM
