'05 TL VSA light
'05 TL VSA light
My vsa light came on and it wouldn't go off unless I turn the car off but it comes right back on again as I drive 20 feet from where I parked at. What can I do to fix this besides going to the dealer
runnin a little boost
You can look around under the car to see if any sensors are disconnected, maybe a wheel speed sensor. Do you have an abs light on? I don't think a regular OBD 2 scanner will pull vsa related codes, but if you have a check engine light on it might be worth a try to have the codes read. Vsa is just traction control and should be fine to drive with for awhile until you find the issue. Unless the abs light is on your braking should be normal, just no traction control.
pull the code
mada51589
05-03-2022 08:54 PM
cycdaniel
12-17-2019 10:58 AM
