'05 TL powersteering pump problem...
Old Feb 13, 2012 | 11:37 AM
daddylos12's Avatar
Red face '05 TL powersteering pump problem...
05" tl 114k
problem:
When i crank the car powersteering fluid gushes out bubbling from resvoir
recebtly had pwrstrnin pump replaced shop says its normal to get air out new pump i call bluff. Anyone lend any insight.
Old Feb 13, 2012 | 11:44 AM
ez12a's Avatar
the overexplainer
replace the o ring. there are a few threads on it if you search for them. either that or there is an air leak somewhere. Check yer hoses too.
Old Feb 13, 2012 | 09:00 PM
Bitter Melon's Avatar
Did you go with an OEM unit or aftermarket?
Old Feb 13, 2012 | 09:40 PM
Bearcat94's Avatar
AZ Community Team
I went with Amsoil.
There is a video in the linked thread that is exactly what the OP describes.
A-105: DIY: Power Steering Pump Rebuild
https://acurazine.com/forums/3g-tl-problems-fixes-114/diy-105-power-steering-whine-fix-754586/ - PS Whine Fix (O-Ring Replacement)
From this page if FAQ/DIY topics: https://acurazine.com/forums/3g-tl-2004-2008-93/3g-tl-garage-faq-3g-tl-newbies-553554/
Old Feb 14, 2012 | 08:51 AM
daddylos12's Avatar
Well just dropped car off at shop.. mechanic. Stuck on air coming in some where... causing to gush.. he says cant b orings cuz id have a leak sumwherehe gonna flush it.. an see if he can locate problem fingers crossed..
Anyone in Houston or know good Houston Acura tl tech
Old Feb 14, 2012 | 02:02 PM
Bearcat94's Avatar
AZ Community Team
Originally Posted by daddylos12
.... Stuck on air coming in some where... causing to gush.. he says cant b orings cuz id have a leak sumwherehe ....
Sorry, but I think he's just plain wrong on this point.
Look at the vid in the linked thread. Same as you describe, fixed with replacement o-ring.
Now perhaps the o-rings/seals are not the problem, but it seems to me you do the most likely thing first - the thing that has been shown to cause the problem and is relativley easy and cheap to fix.
Old Feb 24, 2012 | 10:13 PM
SS_Acura_TL's Avatar
It IS the o-ring. Daddy, do what Bearcat suggests - start with the simplest, cheapest fix first. You will find he's right - a tiny, inexpensive o-ring will cure your woes.
IBankMouse
Jun 13, 2020 12:53 PM
spudweb
May 22, 2016 02:39 PM
Jboat
Sep 30, 2015 10:58 AM
Boraxo
1/2G MDX (2001-2013)
Sep 29, 2015 04:35 PM
