'05 TL fogs don't work...help TL experts
Old Mar 6, 2010 | 12:22 AM
alex05tl's Avatar
i have an 05 tl and the fog lights dont come on....i checked the bulbs and they are good...i also checked the fuses and they are good..anything else i should check?
Old Mar 6, 2010 | 12:39 AM
powerflow's Avatar
Wiggy Wiggy Wiggy
Check these:
• Open in the wiring, or wiring problem.
• Fog relay.
• Combination switch, fog on/off switch.
Old Mar 6, 2010 | 08:00 AM
alex05tl's Avatar
Originally Posted by powerflow
Check these:
• Fog relay.
thanks for the fast reply....where would the relay be located.....i cant seem to find it on the fuse box in the front.
Old Mar 6, 2010 | 08:13 AM
powerflow's Avatar
Wiggy Wiggy Wiggy
It's under the hood, in it's own little housing next to the under hood fuse box / intake area. It's got a square black cap about 1.5" x 1.5".
There is a 2004 factory manual floating around the web. Download it, it has the step by step diagnostic routine.
Old Mar 6, 2010 | 08:17 AM
nfnsquared's Avatar
What fuses did you check? It's #10 (20A) in the underhood fuse box.
Have you modded your fog lights in any way?
You don't have your brights on, do you?
Old Feb 7, 2011 | 08:38 PM
Sezniko's Avatar
Whatever I do what I want
my fog lights won't come on either on my 2006.Fuses and bulbs looks good.All my other lights work fine. I'm unsure on how to test the relays. This happened after trying to independent fog lights mod. So I'm thinking either I shorted a relay or broke the combination switch because there was some sparks when I was spicing the wires on the steering wheel. I have a separate wire and switch with a relay to the factory fogs right now until I can figure out what I broke.
Old Sep 29, 2011 | 11:45 AM
Sezniko's Avatar
When I turn on the factory fog light switch I still get an indicator light on the dash.Is there a way I can tap into that either from the switch since the relay no longer gets power to it?
Old Oct 1, 2011 | 04:50 AM
Nick Tiger's Avatar
A bit premature, but hope you guys are aware that the fogs come on only on with the low beam
Old Jan 28, 2012 | 03:06 PM
Michael higgins's Avatar
Just had this problem. In mine there was a short in the switch. I wiggled it back and forth and they turned on. They will not stay on though
RLX-Sport Hybrid
3G RLX (2013+)
43
Dec 16, 2015 10:45 PM
sockr1
Oct 1, 2015 01:31 AM
Frathora
Sep 28, 2015 11:29 PM
ellisd03tls
Sep 8, 2015 04:17 PM
prox
5G TLX Problems & Fixes
Sep 1, 2015 02:03 AM
