05 Acura serpentine belt jumps half off
Ok. I have been having this issue for about 3 weeks now and I am lost. Everything seems to be lined up except in the power steering pulley. So I changed the idler and tension pulley assembly and nothing. Still doing the same thing. So I got a new serpentine belt and the same thing is happening. Any ideas. Have anyone had a issue with this. I thought of the power steering pump being bad but it moves just fine and it has very little in and out play (about a centimeter). While the belt jumps out on the power steering pulley, EVERYTHING else is aligned. PLEASE HELP.
The car has not have work done to it to cause the belt to jump. Got a ball joint replaced but that's it. I will replace to power steering pump and hopefully it does the job.
a centimeter is a ton of play, maybe u meant a millimeter? there really should be next to no shaft play in any of the pulleys. check your crankshaft pulley too, its a dampener so if the rubber is cracked the outer ring may have some play
I would figure if the crank pulley is bad everything else will follow. That is what gets me. Only the power steering pulley jumps out while everything else is still align. I will check it today tho.
el.profe
02-20-2020 06:26 PM
MarkF786
10-31-2018 07:03 PM
PeteCLS
02-17-2014 11:41 AM
terryt5231
04-10-2013 12:18 PM
