'04 TL trans issue
Old Sep 7, 2012 | 07:40 AM
nismopowerdqg's Avatar
LowNslowTL
'04 TL trans issue
my TL has 162,000 miles on it. every now and then i get a shudder like it is struggling to go into gear between 3-4 gears on upshift. i bought the car used and the trans fluid is dirty and smells burnt but didnt know if i should do a drain and fill or not. i added some conditioner to the trans and it seems to of helped. is this a sign my trans is going bad? also in 5th gear i sometimes hear a grinding noise..also seems to of disipated since conditioner was added. sorry for the rant. thanks!
Old Sep 7, 2012 | 09:34 AM
f.tardif's Avatar
like u read in my thread, change the 3th/4th gear pressure switch and do a drain and fill oil for the tranny oil. it helped mine alot with the fluid was really dirty.
i'll keep u posted for the gear pressure swithc and it will be changed.
Old Sep 8, 2012 | 05:30 PM
pelhamj's Avatar
5th Gear
Is it difficult to do the 3rd & 4th pressure switch changes? Does it require any special tools?
Old Sep 8, 2012 | 06:44 PM
MandoTL's Avatar
^Search is your friend, use google and you will get plenty of results.
Its not difficult but I just got my uncle to change them since I was lazy to change them out.
Link: [for DIY]
https://acurazine.com/forums/3g-tl-2004-2008-93/110-diy-guide-replacing-3rd-4th-gear-pressure-switch-3g-tl-2004-2006-a-729149/
Old Sep 8, 2012 | 08:51 PM
cnjsommers's Avatar
5th Gear
The switches are very easy to change and there is a DIY posted on here with pictures. Took me 15 min. Remove driver side wheel and u can change them easy. You will need two wrenches 10mm and 1 don't recall the other but it's around 21 mm. Have fun
justin7779
Dec 25, 2015 10:33 PM
carz0159
Sep 20, 2015 06:11 PM
jfman55
Sep 5, 2015 02:55 PM
