04' tl trans
Old Dec 28, 2016 | 12:23 PM
jasonmcgee's Avatar
04' tl trans
it goes dead when i stop and it acts like it is trying to start off in 2nd gear and i also hear it making a grinding noise
Old Dec 28, 2016 | 01:11 PM
It's dead Jim
Old Dec 28, 2016 | 03:13 PM
jasonmcgee's Avatar
so i guess the next obvious question is what kind of money can i expect to spend on a rebuild or a used tranny
Old Dec 28, 2016 | 08:23 PM
MarcDavidoff's Avatar
Read this thread..your best option (and will work on your 04)
https://acurazine.com/forums/second-...n-swap-905115/
Old Dec 28, 2016 | 09:14 PM
csmeance's Avatar
sounds like maybe the torque converter is toast and might be sending metal bits through the trans. Look into the accord v6 trans swap.
Old Dec 28, 2016 | 10:10 PM
YeuEmMaiMai's Avatar
do you have any codes for torque converter?
When you drive are your RPMS normal and then go really and stall low as you come to a stop every time or just sometimes?
you can disconnect the solenoid and take it for a short drive and if the problem goes away, you know where the issue is.
Roof_Goof
May 18, 2017 03:11 PM
Ceelojaycee
Dec 26, 2016 02:14 PM
Michael Hinchey
Dec 24, 2016 10:08 AM
hpcacura
Dec 17, 2016 10:02 AM
Brad.weber1990
Dec 9, 2016 01:39 AM
