...'04 TL HID Ballast
... Yes i've search and found out it has to be my ballast that is dead. So this morning on the way to work my driver side bulb doesn't turn on added a new bulb and I see it wanting to turn on in the dark but it doesn't.
So ill have to say yup ballast is done, ill recheck the plugs and stuff, but what do you guys recommend? using OEM ballast? or splicing an aftermarket ballast on it?? ur help is appreciated
I would go OEM on parts like that. There is a VIN break in that year, and I'm not sure if the aftermarket companies recognize this. (depends on if the last of your VIN is before or after 4A032972)
The controll unit and igniter are both around $220 at the dealer, but you may be able to talk them down in price depending on their mark-up.
Being an Acha Bacha in
Call up Matt at the retrofit source. They might be able to make you an ignitor for cheap with OEM parts that works with your TL ballast. You just need the connector on the end that plugs to your ballast. No need to go to the dealer.
And I heard Wed and Thursday might hit 60 degrees!
ABP_04TL (03-06-2012)
Or you could just upgrade to 5five ballasts!
http://www.theretrofitsource.com/product_info.php?products_id=163
Anyways here's a link for the ignitor:
http://www.ebay.com/itm/OEM-Mitsubis...#ht_3720wt_823
MrHeeltoe
20
02-23-2023 01:54 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
