'04 TL electrical problem-no power from battery to car
Old Feb 24, 2014 | 04:36 PM
kleen1965's Avatar
3rd Gear
Unhappy '04 TL electrical problem-no power from battery to car
I have an 04 Acura TL that was running normally when I left on Sat. I hit a large pothole pretty hard, but that may or may not have anything to do with the problem.The car sat for about 30 mins., then when I tried to start it, it was completely dead-no dash lights, no ignition click. Got a jump and that didn't work. One of the terminals was badly corroded. A local mechanic came to look at it, and when he jiggled the cable, the dash lights came on intermittently and the ignition would click when I turned the key.
He replaced the terminals and cleaned the contacts really well, and--nothing. No ignition click, no dash lights. He checked all the fuses and connections, everything had power where it was supposed to and all the fuses looked good. There's a reset button on the fusebox under the hood, so we tried that, and still nothing. Pretty sure he checked all the grounds, too, but we're going to go recheck everything.
Is there anything I'm overlooking? Any suggestions? Nearest dealership is 75 miles away and were no help when I called.
Old Feb 24, 2014 | 05:22 PM
ZOMGVTEK's Avatar
It's probably the main fuse, or the chassis ground.
Old Feb 25, 2014 | 01:53 AM
kleen1965's Avatar
3rd Gear
It WAS the ground...even though backwoods mechanic already (allegedly) checked it. Sorry to have wasted your time. Sooo thankful!
Old Apr 14, 2014 | 09:09 PM
Skunk2racing's Avatar
9th Gear
Which ground caused it? I'm having that same issue and my battery fuse is blown.
Old Apr 14, 2014 | 10:05 PM
kleen1965's Avatar
3rd Gear
It was the chassis ground, I believe.
Feb 25, 2020 09:57 AM
Phambam12
Sep 6, 2015 06:57 PM
jordanboi
Sep 5, 2015 01:33 AM
chrisr
5G TLX Problems & Fixes
Aug 31, 2015 08:24 PM
Aug 30, 2015 02:39 PM
