'04 TL A/C Trouble
Old May 29, 2013 | 04:31 PM
REDSGENESIS's Avatar
7th Gear
'04 TL A/C Trouble
Hey, has anyone had trouble with their AC sometimes not firing up?.. When starting the car it will either start blowing, or sometimes it wont.. When it doesn't after while driving it might kick in after a while.. When it works it's ice cold!.. Any ideas?..
Old May 29, 2013 | 04:57 PM
truonghthe's Avatar
sound like your blower unit is an issue an not your A/C system, reason for it get cold when the fan decide to blow is very simple because A/C is accumulated at the low side radiator but no fan is deliver that cold air therefore it keep accumulate until the blower decide to work then all of that cold air rush into the cabin.
Old May 29, 2013 | 08:33 PM
YeuEmMaiMai's Avatar
Do the self test on the Climate control and it will tell you if everything is working or not. If it throws a code, post it up so people can tell you where to look
Old May 30, 2013 | 08:57 AM
Project_CLean's Avatar
MMkay.
Definitely sounds like a problem with the blower motor itself. Maybe a loose connection?
Biggie_B
May 27, 2025 05:51 PM
08KBP_VA
Oct 22, 2019 01:55 PM
Jinkazetsukai
Nov 21, 2015 05:28 PM
hashbrown
Sep 29, 2015 12:13 PM
